200 fan on 190 series 3
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Topic: 200 fan on 190 series 3
    Posted: 30 Apr 2019 at 6:44pm
Aside from it being a little larger in dimeter, are there any negative effects of swapping the 200 fan in for the 190 fan?
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 6:45pm
should read diameter, not dimeter, sorry!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 7:42pm
Shouldn't be , I think the 200 has 7 blades for drawing more air in
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 9:12pm
Part of that swap would be double fan belts. You have to keep the single belt tight with the old fan to keep it from slipping. You would need crank pulley with two grooves and alternator pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 7:00am
Two belts or don't do it !!!
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 7:11am
Thank you everyone for all the help and advice on this!! I would have never thought of everything that's involved with making this modification, and would have had to learn the hard way...again!
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 8:24am
 mine crank pulley had two groves changedwater pump pulley and alternator pulley used two belts and fan same as 200 it ran much cooler had 125 hp
This page was generated in 0.368 seconds.
