200 allis charging issue |
Post Reply |
K bockting
Bronze Level Joined: 18 Oct 2012 Location: MO Points: 135 |
Posted: 07 Dec 2019 at 7:15am |
Installed rebuilt alt and new reg. Wiring and anmeter look ok. Only getting 12.5
on load tester at batteries. Anything else to check? |
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29773 |
Turn on all your lights and after a while check again
If the batteries are fully charged the alternator won't charge them more. Do your batteries get weak and if so do you still only show 12.5 volts on your volt meter when running? You're using a hand held fluke meter or equivalent. I've had trouble with a cheap load tester Edited by Lonn - 07 Dec 2019 at 7:43am |
Wink I am a Russian Bot |
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11558 |
Make sure the Regulator is properly grounded. Sounds like improper ground at the VR. With "DN" series, or external regulated Alternators, make sure the Alternator case is grounded also. If the Tractor was freshly painted, paint is a great insulator.... HTH Steve@B&B
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Be sure to verify you have the correct regulator. I got the wrong one from AGCO and after replacing all the wiring and it still not charging I went back and found they sent the wrong one.
1957 WD45 dad's first AC
Post Reply | |
