1981 Allis 6080 surging issues
Steve16 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve16 Quote  Post ReplyReply Direct Link To This Post Topic: 1981 Allis 6080 surging issues
    Posted: 07 May 2017 at 9:52pm
I have a 6080 that will run anywhere from 10 minutes to 30 minutes and will then start to surge.  It will surge two or three times and then will die.  It will not restart for 12 - 24 hours and then we repeat the cycle.  I have changed fuel filter - bled lines - changes fuel lines.   Any suggestions?
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 6:05am
Sounds like something in the fuel tank. I just had a similar issue with a 175. I siphoned out the tank and put a piece of 1" hose on the end of the shop vac and sucked the tank out good. It's been fine since but I haven't run it much. Good luck
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 7:02am
Agree
Unless it has a cab not hard at all to pull the tank and clean it.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 7:08am
The shut off tee in the bottom of the tank is known to be easily restricted. Check for a strong flow at the tee.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 8:06am
flex ring breaking down in pump, and the pieces are plugging the return fitting in the top of the pump. Take it out, see if it's plugged, and clean it out and it will buy you some time until you can get the pump rebuilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 8:47am
Following ED,loosen screws holding timing window to relieve pressure and see if it starts right up.If that works,be time for rebuild.
This page was generated in 0.629 seconds.
