1950 WD starter problem
jimwithag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimwithag Quote  Post ReplyReply Direct Link To This Post Topic: 1950 WD starter problem
    Posted: 24 Apr 2011 at 4:45pm
I've replaced the complete shaft/sproket assembly in the starter with orginal new parts and I still have the same problem.  The sproket backs up and locks to tight in the home position, so that when u tried to start it, it spins in place and won't move up the sindle, once I free it up, it works for  a little while, then gets jammed back up against the stop.  This is what was happening to the orginal assembly I had.  Any help would be appreciated. Thanks, Jim
Jim Cridge
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 8:23pm
can you put a washer in for a spacer so it doesn't come back too far? Bob
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 8:07am
Had the same problem on a WD45 once,tried every way to fix,finally bought a complete rebuilt starter.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 3:46pm
   Mine did this when I put the new assembly in. To fix, don't laugh, I put a hose clamp around the shaft so it can't go back so far. Takes a little time to get it situated right but it has been working for me, knock on wood.
http://www.rumelyallis.com
