1944 B PTO Shaft Hole Size and Adapter |
Dean (West MI)
Joined: 12 Sep 2009 Location: West Michigan Points: 1282 |
Topic: 1944 B PTO Shaft Hole Size and AdapterPosted: 21 Jun 2010 at 6:24pm |
www.allischalmers.com : Netcraft / Whois HoIP address : 67.19.58.12 Country : United States (US) Region : Texas City : Houston Latitude : 29.7523 Longitude : -95.367 See on Google Maps I recently purchased a slipper type clutch, PTO adapter for my 1944 Allis Chalmers B. This mechanism coverts the PTO shaft from 1-1/8" to 1-3/16" and has a built in clutch that engages when I press the foot clutch so that the Bush Hog doesn't keep pushing the tractor forward. The only problem is the hole in the B's PTO shaft is 3/16" while the pin size for the adapter is 5/16". Does anyone make an adapter that uses a 3/16" pin or do I simply drill out the hole in the B's shaft to accept the larger 5/16" pin? Thanks in advance for any insight. < ="text/">#flag_userjs {text-align:left;color:black;font-size:10px;font-family:Tahoma;position:relative;z-index:1000;position:fixed;right:0px;top:0px;margin:0;padding:0} #flag_userjs a {color:#0040af;text-decoration:none;border:0}#flag_userjs a:hover{text-decoration:underline;border:0} #flag_userjs .details {position:relative;z-index:10500;display:none;position:absolute;width:20em;top:10px;right:0px;padding:2px 4px;background-color:#fafafa;border:1px solid #aaa;} #flag_userjs .helpDetails {z-index:10100;display:none;position:absolute;width:12em;right:0px;padding:2px 4px;background-color:#fafafa;border:1px solid #aaa;} #flag_userjs .help {display:inline;float:right;}
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 21 Jun 2010 at 9:56pm |
Just use the bolt that fits the PTO shaft. It only holds the devise on the shaft, the splines do the hard work. Bob
Joined: 11 Sep 2009 Location: illinois Points: 89359 |
Posted: 21 Jun 2010 at 10:34pm |
i agree.. your adaptor goes from 1-1/8 to 1-3/8 inch splines. the pin just holds in on. if a 3/16 pin is all you can get in, thats o.k. i have seen cotter pins used on some tractors. dont have to be a roll pin or bolt.
CTuckerNWIL
Posted: 22 Jun 2010 at 7:44am |
Use the smaller bolt that fits the tractor PTO shaft. Just make sure your telescoping driven shaft slides freely front to back.
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Posted: 22 Jun 2010 at 8:20am |
Agree - the extra room in the adaptor hole will only add (maybe) some extra telescoping action which is not an issue. The pin only makes sure that the adaptor won't slide off - the splines do all the work to drive the implement.
WC, CA, D14, WD45
Dean (West MI)
Posted: 22 Jun 2010 at 10:04am |
Thanks for all of the replies, I never thought about using a pin that would fit the PTO shaft. That's why this site is the best! |
