1943 & 1947 Cs - Ex Pullers
wjohn View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: 1943 & 1947 Cs - Ex Pullers
    Posted: Yesterday at 10:42pm
I went to an auction last weekend since there were some AC parts in the pictures. There was a C and then a WD but I don't need any more tractors, right? So I don't drive the big truck and trailer - just the little truck. It was a well attended auction but apparently nobody was interested in the tractors. I ended up with the C and the buyer of the WD was also just outbidding the scrappers. Kind of sad, but I'm glad we saved them. Cs and WDs also aren't the most desirable tractors anymore, I suppose. I also saved a truck bed full of parts.
Then a random guy comes up to me and asks me if I want another C for the same price. He lives close by. I check it out and decide it is also worth the money, even though it hasn't run in two years. I drive back up the next day with my trailer and load them up.
The auction C is a 1943 and the guy used it as a puller. The 28" rears are interesting. I drove it onto my trailer and other than some minor leaks and the usual non-functioning brakes, it seems pretty good. I think it will be a good match for my 11x7 John Deere FB-A grain drill, and for jockeying equipment around my back yard. Maybe I will put 24" wheels back on it and find a cultivator for it someday.
The other C is loose and has quite the homemade 3 point hitch and hydraulic pump setup on the rear. It's a 1947. Ironically the brakes work in that one. I also found a plaques from a couple different local pulls on it, so it was also someone's puller once upon a time. Then I noticed some junk in the bottom of the grille and it turns out someone stuffed some lead weights into it. Those need to go before they damage anything. I have never had any interest in pulling but I guess if I ever have any downtime I could give it a whirl with the '43?
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 20 minutes ago at 11:24pm
Is that a plate of steel made to adapt those wheels?
Or is that a WC wheel center bolted to a C wheel center ?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 53 minutes ago at 5:51am
Good save! Amazing what a guy winds up with going to auctions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 17 minutes ago at 6:27am
Those are two nice finds and both have aftermarket seats which are a plus.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 2 minutes ago at 1:42pm
We pull two Cs; A 1948 Single Front Wheel and a 1950 Wide Front. We've had good success with both of them. Dad's '48 is the current points leader at 2,500 lbs. and sitting in second at 3,000 lbs. I'm currently in first place at 3,000 lbs. with my '50. Last pull of the year is the 30-31 of this month. Yesterday I adapted double wheel centers to my C & gave it a good tune up. I can't let Dad catch meClap BTW we're also sitting in first at 3.500 & 4,000 with two of our WCs!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 44 minutes ago at 8:00pm
There are a set of steel plates to adapt the rims to the C center.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 36 minutes ago at 8:08pm
Problems, Mike... Problems. That's what I end up with when I go. Ha.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 16 minutes ago at 8:28pm
I think the 1943 tractor has a Monroe on it, but I haven't figured out what the seat is on the tractor with the 3 point hitch (1947). I have a WD45 that has the same seat (pictures can be seen here: https://www.allischalmers.com/forum/1953-and-1955-wd45s_topic204010.html) but with mounting specific to the WD45. The little adjustment handle up front seems like it would make it easy to ID if I could find anything about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 6 minutes ago at 8:38pm
Nice! I talked to the owner of the '43 after the auction and he pulled 2500 and 3000 classes with it. The plaques stuck to the '47 all say 2500 class.
