1939 AC B crankshaft pulley needed
GWHunter3333 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GWHunter3333 Quote  Post ReplyReply Direct Link To This Post Topic: 1939 AC B crankshaft pulley needed
    Posted: 30 Apr 2017 at 4:17pm
Hi, I have a 1939 Allis Chalmers B that I just bought last week. Runs good when I can get the crank to not slip but it needs a new crankshaft pulley bad. The hand crank itself is ok. Anyone have a good used one they would sell me? I can find replacement crankshaft pulleys but not any that have the slot for hand crank.
Thanks!
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 4:37pm
Not knowing how your looks but if not broke way far back some can be ground to catch the crank on both sides .
Post Options Post Options   Thanks (0) Thanks(0)   Quote GWHunter3333 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2017 at 10:00pm
I will post a picture asap.
OldsmobileGlory View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldsmobileGlory Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 10:49pm
Dick, this is Brian from Ohio, we broke our pulley rebuilding the motor in our B. Is there a hand crank one out there?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 5:04am
Do you ever get West on the pike to the Indiana line?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 12:38pm
When buying used ones, many will be cracked from improper removal. When I see them loose at swap meets, more are cracked than are usable.
Edited by PaulB - 11 Jul 2017 at 4:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldsmobileGlory Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 3:21pm
Not usually
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 4:20pm
I probably have one Mike. I'll check here soon for ya.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 6:03pm
Not usually
I might have to pull one off an old engine. I had several in the shed somewhere! I'll take a look when I do chores. I think I have two old stuck engines with good pulleys.
RLBPA1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 8:19pm
Just put one on ebay. Great shape lots of pictures from a 48 c I am parting out.
This page was generated in 0.085 seconds.
