1936 Model WM
cabbagehats View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabbagehats Quote  Post ReplyReply Direct Link To This Post Topic: 1936 Model WM
    Posted: 30 Jun 2017 at 11:24pm
Hey howdy! New to the forum, just got my Great Grandpa's '36 Allis Chalmers Model WM delivered closer to home so I can fix and use it. It's a wide track model with extra wide grousers. Needs some love but I got the magneto rebuilt and the engine is not frozen. Tracks are free and one of the steering clutches broke loose while they were loading it. The other one is still stuck.
It's crank start but I heard there's some modern starters that will bolt right up? Would I need to convert to 12v?
I would like to get a blade for it, might need to fabricobble one. Where are the blade mounts in the track assemblies?
Tanks are super rusty, as is the radiator. Best methods for cleaning those?
I think that's it. Thanks, and I hope you like it!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 11:48pm
thats a real keeper there
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 12:22pm
You wont find a blade for that one. That has swamp pads on it, really rare.
Do you need a dozer? If so i would start with something more common and newer for the parts availabilty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabbagehats Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 1:53pm
Are the blades on these all home build then? or is it the fact that it is extra wide?
Yeah kind of, I do have an opportunity on a 1950s International  dozer that was completely rebuild. Part of putting a blade on this would be the fun of doing it. Going to restore it regardless. Don't have any need for a farm tractor, I need a skidder or a dozer. However, I could easily just have a blast roaming the hills in this.
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 4:28pm
Wow that is neat! it sure looks like a fun to drive machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 5:00pm
Great to save an old Family tool.
 It might make a good bush hoggin unit Big smile I have an overgrown pasture I try to mow best I can with the tractor, but there are SO many different thorny things out there, it would be nice to be on steel and not have to fix a flat again!
Edited by CTuckerNWIL - 01 Jul 2017 at 5:05pm
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 6:10pm
Mine has a home built apparatus for a dozer blade.  I plan to remove it if I can find a pto unit for it, don't know why, probably won't use it either.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 7:56pm
So JW, Did you ever get it out of gear? lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 8:15pm
Yep, paddled across the yard in 4th gear just because I could.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabbagehats Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 2:56pm
Thanks! I wouldn't know, but I hope to find out LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabbagehats Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 3:00pm
Can you get some steel wheels? I tend to do most everything with a handheld brush cutter. Heavy string does almost everything I want to cut. metal blades are a little scary in the summer here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabbagehats Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2017 at 3:03pm
Would be grateful if you posted a picture of your home build blade. Looking for a PTO as well, preferably the gear reduction one.
34 Airflow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 34 Airflow Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 8:07pm
Great job in keeping that part of your family history!
1937 Model A, 1937 Model U, 1929 United, 1945 Model C, 1949 WF, 1948 WC, 1956 D272 and a Roto Baler
http://www.australianallischalmersregistry.com/
DakotaSteve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 8:44pm
Awesome stuff! Keep us posted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 9:08pm
Here's a link to the thread that has a picture.  Scroll down to my post about her crawler, an M but without the blade but does show the cylinders and framework.
http://allischalmers.com/forum/a-show-she-wont-ever-forget_topic139792.html
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 9:26pm
I have a m that has the baker blade that I would sell. Ryan 402-469-1738
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabbagehats Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 9:33pm
Great thread! And that picture without the blade is exactly what I was looking for, thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabbagehats Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2017 at 9:37pm
Think I'm gonna be tied up with this one for a while, but thanks! If I can scrape enough together for a heavy trailer and and truck to pull it I'll be there in a heart beat Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabbagehats Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2017 at 11:13pm
Little update, just done dickering with the crawler today. Cleaned out some mud daubers from the exhaust, kicked out some paper wasps from the air cleaner, shook out some wasps from the carb, pulled some moths i think from the combustion chamber. Then I timed up the magneto, cleaned the plugs, new wires, poured in a little gas and started cranking. Did that off and on all day and got maybe a slight cough or two. I got blisters on my fingers. Was packing up when I thought I'd stuff a rag in the exhaust and see if I could push it out with the compression. Instead the rag got sucked in. So looks like stuck valves and now I really gotta get into it! Should be fun. Anyone want pictures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DakotaSteve Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2017 at 11:15pm
SON OF A!
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2017 at 12:56am
Of course we want pictures!!!
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabbagehats Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2017 at 1:21am
Ok then :) Hopefully I can get back to it next weekend.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 6:53am
do those tracks look backwards to ya'll? Or am I just crazy?
This page was generated in 0.336 seconds.
