1929 20-35 Engines
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: 1929 20-35 Engines
    Posted: 24 Sep 2016 at 5:40pm
Did the 20 - 35 have more than one motor in its lifetime. I know of a 20-35 serial number 195585 that has an engine serial number of 45222. Is that an Allis engine or what. Thanks for all help.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 9:22pm
I'm not sure what you are asking exactly.  Your engine serial number of 45,222 would be about right for a 1929 20-35.
But a tractor serial number of 195,585 is way too big for a 20-35.  So I'm confused by that, it must be a typo or misread?
The engines did have changes over the years.  But for the most part were the same except for updates through the years.  When they changed to 25-40's things changed quite a bit again.  But that tractor serial number is too big even for a 25-40.
You'll have to be more clear on what you are trying to figure out, then we can help more.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 11:06pm
SN is 19585    The owner says his engine is different than most 20-35, he says carburetor is on opposite side.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 11:13pm
20-35 Special? They have more power. Not sure what's different about the engine though.
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 8:38am
The carb. and manifold is on the right side of engine from the 18-30 to the end of the a. The governor for the 18-30 and 20-35 is on the left, but was changed to the right side for the 25-40 and a
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 10:05am
Need pictures to see what we are talking about.  I've seen some cobbled up 20-35's but never seen one yet with a non-Allis engine!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 7:05pm
Upon looking at the 20-35 closer, it appears to have an engine from an "A"  Is that possible, will an "A" engine bolt up in a 20-35  ??
Brad-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 1:54pm
Yes, with the correct adapter plate.  A 25-40 is essentially a 20-35 rear end and transmission with an A motor bolted up to the front of it.  Now that I think about it, the adapter plate is for the A and the motor bolts up direct with the 20-35 rear end and trans for the 25-40....no adapter plate necessary to have a 20-35 with an A motor.
Edited by Brad-MN - 26 Sep 2016 at 1:55pm
1930 U
1938 A
1941 WF
