190xt transmission dilemma |
MadCow
Joined: 27 Aug 2023 Location: South Dakota Points: 186 |
Topic: 190xt transmission dilemmaPosted: 26 Jan 2026 at 11:16pm |
I have a gas 190XT, snap coupler. I prefer snap coupler, and since everything I have is gas, I prefer gas. I also like the sound of it running better. It also doesn't have the weird horse door cab where the one door opens in and the top opens out.
I have a 190XT diesel. 3pt. Recently "overhauled" (don't know exactly what) engine. It has the factory cab with the dorky doors. However. The diesel doesn't jump any gears. Goes in hard and solid and stays. The gas jumps out of second. Up hill, down hill, load, no load. With a bungie cord hooked up right it's mitigated. I put maybe 150 hours on all tractors combined a year. And I do like mechanical work. I'm slowly building up and this is the tractor that'll be growing with me. So the question is: Do I go with the diesel and swap all the snap coupler stuff over? Do I try to swap the transmissions and hitches so the gas has the best of it all? Do I calibrate my bungee cord and wait for a transmission rebuild? 1st, 3rd, 4th, reverse all work fine. And I do really prefer the gas over the diesel. This is far planning, just changes whether I sell the extra tractor now, or hold on or swap. |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4231 |
Posted: 18 hours 36 minutes ago at 7:09am |
If I were you I'd keep both and fix the tranny in the gas tractor. Can't imagine getting rid of a good running 190 D.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1570 |
Posted: 17 hours 20 minutes ago at 8:25am |
Those 190 diesels seem to be desirable. I would keep both in their original state. I would like one myself but unfortunately have no use for it.
A&Sfarms
Joined: 02 Nov 2021 Location: Fletcher, Ohio Points: 23 |
Posted: 12 hours 18 minutes ago at 1:27pm |
Tractor Data says the gas uses 7.2 gal/hour and the diesel uses 5.3 gal/hour at rated speed. Something to consider since you said it will be the tractor you grow with. We are all out here waiting for input costs to come down... Plus the diesel will be cheaper to operate considering it doesn't have transmission problems. Our 7060 sits fairly often because the XT is so much cheaper to run
Posted: 6 hours 28 minutes ago at 7:17pm |
At least remove the shift cover and take a look. Maybe you just have a broken shift fork? Wouldn't that be nice !!
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3159 |
Posted: 4 hours 57 minutes ago at 8:48pm |
I had a gas 190XT for a few years used to bale with it,burned about 4 gal/hour
