190XT Steering Problem |
bttpe1961
Joined: 5 hours 26 minutes ago Location: Columbia, MO Points: 3 |
Topic: 190XT Steering ProblemPosted: 5 hours 22 minutes ago at 8:14am |
Our 190XT stopped steering. So far what I see is that there is no fluid flowing out of either hose going to the steering cylinder. My assumption is that the steering pump has failed. Do you guys agree? The lift on the back still works. I'm reading that there are 3 separate pumps and one is dedicated to the steering and likely needs rebuilding.
Posted: 2 hours 43 minutes ago at 10:53am |
If the steering pump isn't pumping any oil, the tractor will NOT MOVE and pull any kind of a load. Yes or No ?? Power Director clutch creeping doesn't count as moving.
bttpe1961
Posted: 0 hours 60 minutes ago at 12:36pm |
Moved it 40 ft - it moved sluggishly.
Posted: 14 minutes ago at 1:22pm |
It doesn't really move and able to pull a load. On the back section of the hydraulic pump is a large hex plug facing out at you. Probably take a socket bigger than 1 1/4" to remove it. Remove the plug and spring and dig out the spool inside. The spool should slide freely in and out. Make sure it does. This is where to start.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5425 |
Posted: 4 minutes ago at 1:32pm |
Assuming fluid levels have been checked? Sump screen been cleaned?
