190xt series 3 diesel high/low question
rudyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Topic: 190xt series 3 diesel high/low question
    Posted: 04 Apr 2017 at 8:37pm
I have a 190xt, it doesnt seem to want to run on the high side.
Pulls great on the low side, when I put it high it will pull but doesnt seem like it is fully engaging. I checked to see if the likage was sloppy, though it seemed it was fully in gear I pulled up on the linkage under the platform to check.
Any advice is appreciatied.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 9:06pm
If linkage is all good and adjusted to where it is moving spool all the way, may have a bunch of broken plates on hi side.       MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 6:47am
Had the high side fail on my 200 (actually bought it that way a year ago). Had an local former AC dealer, now repair shop and auctioneer, do the repair. At $75/hour came to $2000. That included another split to repair a leak on the clutch shaft in the bell housing. Needed all new plates on the high side. Without the second split I'm guessing it would be around $1,500 or so just so you have an idea of possible cost.
Wink
I am a Russian Bot
