190xt relif valve no longer avalible. |
prospolaris ![]() Silver Level ![]() ![]() Joined: 17 Aug 2010 Location: nj Points: 84 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Oct 2011 at 3:30pm |
so as i mentioned on past post i bought a 190xt that would not steer. as taking the rear section off the pump the floe divider was stuck. well i thought i was goldin. not so easy. the previous owner took out the relif valve in the next port over thinking this would cure the issue. well eeeeeehe did away with it and parked the tractor after not working. so i went to the local agco dealer and the part is no longer avalible.AHHHH so now the only was i can get this little relif valve is to get a new or used pump. $950. great.......... this is where i ask you guys for some help. any one have one? or a used pump that u wouldnt mind selling me the releif valve out of? any help would be great.
I should have a used relief valve. Can check in the morning. MACK 660 828 4310
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
well...there was a 190 forsale in another post, it should have what you need and more!!
