190xt rear wheel removal help
whizone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Topic: 190xt rear wheel removal help
    Posted: 16 Aug 2018 at 10:02am
Can anyone explain simply how to remove the rear wheels with weights (700's) off my 65' 190xt?  There is a hub with 3 big bolts which looks like its wedged in around the axle somehow..  These tires/wheels are big and look extreemly heavy so I want to know what I am doing so as to not get hurt or tear things up..  thanks.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 10:06am
special pusher bolts to remove the wedge from the cast center.  they can be very difficult to remove sometimes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 10:10am
Any idea where you may find these special pusher bolts?   I had an idea this may be tough.. Thanks much.
LRWSPWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LRWSPWI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 11:00am
If they are the same as my 200, I ended up making my own 3/4" coarse thread grade 8 bolts with a 5/8" grade 8 bolt (without head) welded to it. I don't have the dimensions in front of me but I've seen similar ones pictured on the site before. They are a pain, took me two weeks of spraying WD- 40 and hammering around the hub before they would move. Hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 11:05am
Some example pics and instructions would surely help.  Im not sure I can pull this off from the sound of things..  thanks
Allis Magoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Magoo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 12:41pm
If you dont have the bolts get some good normal grade 8 bolts and cover the hole in the hub with 1/4 in pieces of steel and just run the bolts against the plates. Be sure to tighten each one in a pattern to keep the tension uniform.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 1:32pm
...and has been said that when totally torqued up(pusher bolts) WHACK the end of axle with biggest sledge you can swing.It will help loosen wedges.I did it the hard way before I heard that one.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 2:44pm
You could push a 1/4" core of that plate into the threaded hole boogering up the threads. Did that on my D19, then I bought the right bolts. Still was a bear but I have learned a lot since then.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 2:52pm
Get the pusher bolts by hook or by crook. You could have a machine shop make them from non Chinese grade 8 bolts, 3/4" NC thread and machined down to 5/8"? solid peg to fit into hole of cast wheel. I could get exact measurements if need be.
Then evenly torque them up but goooood and if they don't budge the wheel then take a rosebud torch and heat the wheel center around the wedge and give each bolt a nudge now and then. Probably get by heating without even burning the paint. If that doesn't do it then do as suggested with a 16# sledgehammer hit squarely and very hard on the flat end of the axle.
I bet you won't need to go to the sledgehammer.
Wink
I am a Russian Bot
hillmonkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 4:12pm
sorry link not pulling up the thread. google "allis pusher bolts" and then go to the  yesterdays tractor thread. shows specs on bolts
Edited by hillmonkey - 16 Aug 2018 at 4:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 4:14pm
Sounds like great advice.. thanks to you an to everyone for all the help.. GREAT SOURCE FOR INFO!!!!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 8:57pm
Follow the instructions above.  Don't try to rush things.  The hub will probably have trouble sliding off the axle.  Whatever you do, do not pry apart the slot that is in the hub - you can break it in 2.  To slide the hub off, we sanded the axle so it was smoother, then heated the hub with a propane torch, but it still took a lot of hammering!  The best way to handle the wheel center is with a cherry picker.  They are heavy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2018 at 9:13pm
the whacking the end requires the tire to be jacked off the ground
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 7:24am
Indeed, same with just using the pusher bolts to begin with.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 7:27am
A big puller works well to remove the wedge hub along with a big hammer but you still need to sand the axle smooth.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 7:51am
As bad as they can be to move, a stuck wheel on a 4020 is way way worse. And a loose wheel on an IH will cost you dollars.
Wink
I am a Russian Bot
