190XT Rear axle diameterj
GARY1967 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY1967 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Rear axle diameterj
    Posted: 10 Aug 2012 at 7:24pm
Hello,
I hate to ask what might sound as stupid, but asking anyway. Does anyone know if all axle diameters are the same for a 190XT? I have a 1966 gas with what appears to be 3 1/4 inch, with 18.4x34 tires. i have a chance to replace with 18.4X38 and it appears axle is smaller in diameter on the this tractor. Both tractors are 190's with spin out wheels and the only difference is axle diameter? I think the other tractor might be newer, not sure. So if any one knows or where I could find out, please respond.
Thanks
Gary
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 8:40pm
well i think if i remember right the earley 190XT had 3 1/8 in axel and the ser 3 had 3 1/4 in axel but if the earley ones were replaced thay replaced them with the larger 3 1/4 axel (i think this is the way it was ) i know the series 3 had larger axels.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Roger D Slaughter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger D Slaughter Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 8:44pm
I changed from 34 to 38 tires on my 190 gas .  The axel on the 190 was smaller than the 38 inch wedges so I  went a hydraulic cylinder rebuilder and bought a   piece of tube.  The inside dia is the same as the axel and outside the same as inside of the wedge.  I split the tube with a plasma  cutter so the key would fit .   You also have to add a strip of flat iron on to the key to  make up for the thickness of the tube.    Been on this tractor for 12 years and hasen't moved .
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 8:47pm
older ones were 2 3/4 same as a d19. I believe its 2 3/4 i know their the same as 19s. Newer ones and the older ones that were updated are 3 1/4 but hub castings are all the same you just have to use the wedges proper to the axle.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 10:01am
just make sure you keep the wedges with the right axels. The cast centers will interchange. You already have what you need. just put the wedges back on the tractor they came off of.and swap the centers
                                                 IG
