190xt overhaul |
190xt MN
Topic: 190xt overhaulPosted: 13 Mar 2026 at 11:13am |
Hi have a question on my 190xt 3 that I just overhauled. I’ve only ran it for about 5 minutes since we got it back together, I just moved it from one side of the shop to the other while I wait for an avabile dyno to break it in. It doesn’t seem to be getting a lot of oil to the rocker arms. There is plenty of flow from the port in the head and once it fills the rocker shaft, there is plenty of oil going out the outlet tube. Nothing is leaking by the corks in each end that I can see. I dissambled the rocker arm shaft and cleaned out all the small passages in the shaft for oil to pass through. Then cleaned the rockers themselves and reassembled. I used some lubriplate on the rockers during reassembly. I think the cold 15w 40 is just taking its time getting to everything. There is some oil on the bottom of most of the rocker arms and I wouldn’t be too worried about it only I know that the drain oil off the head is one of the ways the cam bearings are oiled, and those bearings along with the cam are new. My Question is if I run it some more and get the oil good and hot, then check how much oil is up top, do I risk cam bearing or cam damage? Or will the cam bearings and cam get some splash lubrication from the crank also. Thanks in advance for any replies.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3649 |
Posted: 14 Mar 2026 at 12:40pm |
It usually takes a few minutes after an over haul to get to a splashing situation from the rockers. IF you lubed the cam brgs well you will be ok. Never heard of a cam brg issue on a 301 or its cousins. Party on...
NEVER green
Posted: 14 Mar 2026 at 1:52pm |
Remove the outlet tube and put a plug in it.
190xt MN
Posted: 16 Mar 2026 at 8:35am |
I’ll run it till the oil is warm and then check agian. However, I’ll keep plugging that outlet in mind just in case. As far as putting the tractor on the dyno, does anyone have a time frame or pattern for breaking it in that you consistently follow? The instructions on the kit only added up to about 45 minutes of run time. That doesn’t seem like enough time, but maybe it is.
190xt MN
Posted: 22 Mar 2026 at 10:40am |
Hello. Got my xt broke in on the dyno yesterday. Excluding a substantial front main seal leak that I have to fix, it went well. Only problem is the oil pressure. When it got good and warmed up, I was around 30 psi wide open and I had to adjust the pressure regulator in to get that. So I was somewhat below min spec. Before the tractor was overhauled, I could still get 35 with hot oil with the pressure regulator backed off from where it is now. I didn’t do anything with the oil pump other then remove the gear set to clean all the old oil and any crud out of the pump, and then put it back together. The gears did not look bad at all. My question is, where do I start looking for the low oil pressure cause? Would it hurt anything if I plugged the outlet tube on the rocker arm shaft then re checked the pressure? I did dissemble the rocker shaft and gave it the same treatment that I gave the oil pump. If anybody is wondering, with the dyno at the 540 rpm mark, it was putting out 98hp. I didn’t pull it down any more then that as what I do with it doesn’t require any more power and that and it was right where it was supposed to be anyway. Sorry for the long post, thanks in advance for any replies!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8979 |
Posted: 22 Mar 2026 at 1:28pm |
First I'd find another gauge to try and see if it reads same.
Posted: 22 Mar 2026 at 1:31pm |
To be clear: the pressure regulator you are adjusting does NOT do anything once the engine oil warms up, as it is CLOSED. It is there to relieve oil pressure only when pressures exceed 55 to maybe 60 PSI, and that would be with cold oil. So, proper regulator adjustment is done when you first start the engine and throttle it up with cold oil temps and adjust it to that 55 to 60 PSI range. Once engine oil is at operating temps, that regulator does nothing as it is closed. There is a steel seat down inside that pressure regulator passage that could be worn. That would allow leakage and could give you lower than desired oil pressures when the oil is fully warmed up. Blocking the rocker arm front oil drain tube probably won't make enough difference to really change the oil pressure numbers. Where are you measuring the oil pressure ?? Are you using a 100 psi or less gauge ?? Was the crankshaft reground for undersized bearings?? or just reused with new bearings ?? Oil pressure when warmed up fully is determined by the leakage at 7 main bearings and 6 connecting rod bearings. If they are too loose, your pressure will be lower. This assumes the oil pump GPM is adequate and within specs.
190xt MN
Posted: 22 Mar 2026 at 1:54pm |
Steve: to answer your question I did verify with another guage and it read the same.
Dr Allis: I plumbed a gauge in a while ago at the same spot the oil pressure sensor was. That’s where I’m taking the reading from. I just have a 1/8 in copper line running up to a gauge on the dash. The range of the gauge on the tractor is 0 to 80 psi. The tractor had been overhauled once before in the 70’s. The rods were ground .10 and the mains were left standard. The crank journals were in good enough shape that the machine shop just polished the journals. I plasti gauged everything before assembly and the mains varied from .003 to .004 oil clearence. The rods varied from .002 to .003, so they are on the looser end of the spec. If oil pressure is lower due to that, will that shorten my engine life somewhat? |
Thanks(1)
Posted: 22 Mar 2026 at 4:32pm |
So, if you changed nothing but new bearings on the crank (same oil pump and same crankshaft) the only thing that has been changed is the main and rod bearings. (I just looked at specs and it is 30 to 55 not 35 to 55 like I thought.) The leakage must be the bearing clearances. I think I'd get some more run time on it and see where you finally wind up on a hot day at a slow idle say 700-750 RPM. What weight oil ??? 15W-40 ??
190xt MN
Posted: 22 Mar 2026 at 6:01pm |
Yup. Same crank, just new bearings. The rest of the project was fairly major: they checked the block line bore, machined it for lower bore inserts, went through the head installed new cam bearings and I ended up putting in a new cam and lifters. The parts were at the machine shop for 3 months and showed up right before harvest started. Also did the Hydraulic pump and put a heavy duty 6 pad clutch in it. It was apart for so long I didn’t remember what it was like to drive it!! 😂😂 I’ll run it some more and keep an eye on it. As far as the oil, I’m running T 4 15w 40 rotella. Thank you for your advice!
DanWi
Posted: 22 Mar 2026 at 6:13pm |
Screw an oil pressure gauge right into the elbow that feeds your turbo. There should be a plug on it same size as a pressure gauge
Skip, W.Pa
Posted: 22 Mar 2026 at 7:34pm |
I read that you had oil pump apart and gears looked good. Gears most always look good, it is not the gears but the clearance between tooth tips and the pump housing that is the issue. I hope you checked that with a feeler gauge. How do I know .. there is two worn 301 pumps in my shop now. The housings are soft cast iron, gears are hard , housings wear out and pump is inefficient. Just a thought as I am reading your post. I have rebuilt countless 50 year old tractor engines that had worn pump housings. Hope you get it figured out , makes a guy loose sleep, been there, good luck.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5465 |
Posted: 22 Mar 2026 at 10:13pm |
My XT runs in the R to M of the gauge, so 35-40 psi hot ever since I’ve owned it. 80 psi AGCO gauge. Cold maybe 50 psi. A little blow by, but not bad for a 4k hr engine. Just as a reference. Not sure if this info helps or not? I’m running T4 15W-40 Rotella
Edited by AC720Man - 22 Mar 2026 at 10:25pm |
190xt MN
Posted: 23 Mar 2026 at 7:38am |
Thanks for all the replies. Found a few more oil leaks, so I have to do some disassembling for repair. Disappointing, but could have been worse. I might be having to drop the oil pan, if I do I’m going to have another look at the oil pump. I’ll keep you guys posted.
Posted: 23 Mar 2026 at 11:52am |
I don't know where or what your leaks are, or how much disassembly you're going to do to dry them up. I do know if it was mine, I wouldn't just be dropping the pan back off looking for "the needle in the haystack" without more information to work with. I had a co-worker finish a Cat C-15 engine OH about 6 months ago. I'm the dyno test tech, so it's up to me to be sure things are correct before it gets released back to the customer or his machine. I had 70+ psi oil pressure cold. Within 30 minutes of 100% load on the dyno, it was down to 35 to 37 psi. I refused to pass it. I told him I suspicioned a main or rod bearing clearance issue. He had to drop the pan and start looking. He didn't agree with me and went his own way. First the fresh "reman" oil pump was replaced with another. He reassembled and I got to test it again and the same results. The second time he then started plasti-gauging bearings and comparing p/n/'s of new bearing shells versus the ones he removed. He had STD main bearings where the old ones were -.010" bearings. So, it can and does happen. You haven't run this long enough to really get it HOT, like 180 degree engine oil temps, which is what it will be in the field working it. I don't think you know if it could make 70 psi of COLD psi by adjusting the relief screw in some more. If it can and if the PSI continues to drop the hotter it gets, I'm not thinking oil pump. You said it used to have 35 ?? psi before this OH ?? So with the same oil pump, why would it now be less ???...........bearing clearances.
190xt MN
Posted: 23 Mar 2026 at 12:55pm |
Dr.. the two oil leaks I have are the front crank seal and one really pesky one that is right in the center of the flange on the oil pan that bolts to the rear structure. I’m going to run it some more tonight just to verify the leak on the pan is where I think it is, and move it to a different spot in the shop. The front seal was a reliance one that came with the kit, I think I’ll try an AGCO one this time. I agree with you that it’s probably bearing clearances. I could get to 30 no load Saturday after I dynod it, I’m going to do what you suggested and take it out and put some hours on it after I fix the leaks to see what is what. By the way, I just caught the post about you starting a shop after retirement. I hope it’s going good so far!!
190xt MN
Posted: 27 Mar 2026 at 5:21pm |
Question… has anyone had a leaking front main seal where the seal spun some in the bore and started leaking? If so, what have you found to be the best way to repair it? I thought about some loctite or JB weld, but then if it would happen to leak agian, might be a little hard to get back apart. Thanks in advance for any replies!
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2483 |
Posted: 27 Mar 2026 at 9:05pm |
I've never seen or even heard of something like that happening. If the seal wasn't fully pressed into the bore and against the step, maybe it was rubbing on the pulley???
SteveM C/IL
Posted: 28 Mar 2026 at 10:48pm |
can't imagine any seal turning in bore vs the lip on the shaft
orangereborn
Posted: 28 Mar 2026 at 11:44pm |
Metric seal???
Posted: Yesterday at 7:06am |
They never spin in the timing cover bore. You gotta use dynamite to get them removed if you change one in chassis.
190xt MN
Posted: Yesterday at 11:19am |
Yeah, I changed the front seal about 5 years ago when I had the harmonic balancer rebuilt. I did get that one out with screws and a prybar, but it definitely was a fight. I’m ordering another seal today. The one I had put in was out of the reliance overhaul kit, going to try a genuine agco seal as maybe this one is a dud. I have the timing cover on the workbench right now, and I can push the seal in down to the stop in the cover with my hands.
Lynn Marshall
Posted: 14 hours 52 minutes ago at 8:37pm |
Well,that ain't right. That seal is a tight fit in the cover.
190xt MN
Posted: 4 hours 38 minutes ago at 6:51am |
Yeah, it was a tighter fit when I first installed it. Maybe the seal itself was made incorrectly. I’m going to order a agco one and see if that’s a tight fit like it is supposed to be.
