190XT hydraulics
Dwayne TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Topic: 190XT hydraulics
    Posted: 14 Aug 2012 at 1:22pm
I used the 190 to move hay about a week ago.  Started it again Sunday and nothing moves - 3pt won't go up, power steering won't work, shifting the power director only causes a little bump forward.  Last time I used for about an hour and didn't notice anything unusual except for the power steering getting a little stiff toward the end.
I checked the easy stuff - plenty of fluid, filter is clear and full of fluid.  That's as far as I went.  What's next?
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 4:01pm
mine done that and it was loose bolts on the pump letting it suck air,.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 7:28pm
Flow divider on the top of the pump stuck.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 8:48pm
It's not the flow divider if the lift does not work also. It could be an air leak in the pump suction line or maybe a clogged screen in the sump. A bad pump is the other possibility.
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2012 at 10:03pm
Mine had a bad (hardened) seal on the pump drive shaft. Also changed the other orings for the pump manifold as they were hard too. While the manifold was off I cleaned it real good.
