190XT Engine Swap
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Engine Swap
    Posted: 18 Sep 2016 at 9:21am
I know a guy that has a 190XT that the engine went down and he bought a 200 engine to go in it but says it won't fit. I haven't looked at it yet but I know some of you guys have done this swap so what say you.JP
'59 D14 '68 170 Diesel '81 7020 40 All Crop
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 9:53am
Don't know exactly but I would say it's something concerning the deeper oil pan on the 200
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 10:28am
Maybe oil pan, little bit of radiator differences, the front pulley maybe a 4 belt pulley, everything else should bolt right up!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 8:49pm
Will have to raise front end so deeper oil pan will clear front axle.  MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 9:55pm
doug got it,, the engine will not fit with the 200 crank  pulley - the axle will hit the pan, the fan will not line up to the shroud.  Change the pulley, add 3" to the pivot and modify the shroud...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 7:39pm
Thanks for the help.JP
