190xt diesel |
ironac
Joined: 06 Jan 2011 Location: Plainfield IA Points: 283 |
Topic: 190xt dieselPosted: 26 Apr 2014 at 2:00pm |
Took home a 190xt diesel series 3 a few weeks ago. It has a lope to it at idle. It's not as bad after it warms up but still doesn't sound right. It runs great at higher rpm's. I changed all fluids and filters. No change. Also the pto doesn't stop when you disengage it. It's a 1000 rpm pto. Any thought?
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5149 |
Posted: 26 Apr 2014 at 5:03pm |
usually a surge or hunting idle indicates the flex ring in the pump is completely gone, and the weight carrier is just slapping back and forth in the slot for the rivets. Once a load is applied, it will smooth out. Pretty common thing.
ironac
Posted: 26 Apr 2014 at 5:29pm |
Okay is it hard to replace or do I need to send the pump in. I'd prefer not to until field work is done.
Pete from IL
Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
Posted: 26 Apr 2014 at 7:05pm |
I think you need to send it in. It may not last the season.
injpumpEd
Posted: 27 Apr 2014 at 8:34am |
It requires sending to a qualified pump shop for best results. It will probably get you through the busy season, then you can pull it off and get it rebuilt. Guessing on the pto that it's a hydraulic clutch, and it has either a linkage issue, or the pto clutch is smoked and welded together.
critter
Silver Level Access
Posted: 27 Apr 2014 at 8:50am |
I would say ED's on the right track about the pto if it's hydraulic but it could also be the brake may need new seals, does it turn at full speed or just slowly turning?
Slade (TN)
Posted: 27 Apr 2014 at 9:33am |
Check timing too....esp if its new to you tractor, a 190 in the shop the other day was sitting on 11°
Slade |
johnea4
Posted: 28 Apr 2014 at 8:38pm |
My XT lopes at cold idle also, i thought this might be the problem. But it started doing something new yesterday: under load (discing) it gradually starts "missing" and losing power. if i turn it off and restart it does fine for a while. is this a pump problem also or fuel supply problem? I haven't had time to blow the lines out yet to see if theres crap in them.
injpumpEd
Posted: 28 Apr 2014 at 8:42pm |
Same problem. The broken flex ring material is plugging the return fitting and return flow from the pump, causing the housing pressure to rise, until it finally just kills the engine. Very common problem with the Roosa pump. Time for a routine freshen up.
johnea4
Posted: 29 Apr 2014 at 5:51am |
Great. Like ironac, i wonder if it'll make it through the season. Better call an injection shop today... Thanks for the advice.
gerkendave
Joined: 08 Jul 2013 Location: York, Nebraska Points: 568 |
Posted: 29 Apr 2014 at 6:56am |
My 190XT seems to lope at a cold idle but when warm it smooths right out. I always assumed it was maybe turned up a bit causing it to lope a bit at idle but maybe not? Am I looking wet the same problem here?
wekracer
Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
Posted: 29 Apr 2014 at 7:40am |
my 6080 does that when cold. Is it the same problem.
injpumpEd
Posted: 29 Apr 2014 at 7:51am |
Very likely. Most of these older tractors that have not had the pump serviced and updated within the last 20 years or so, will start having problems with the flex ring. Today's fuels seem to attack it faster than the old days. Just something to be prepared for.
gerkendave
Posted: 29 Apr 2014 at 9:25am |
What will happen when the flex ring fails completely? Will it just not run or.will it not respond to throttle input? What happens?
injpumpEd
Posted: 29 Apr 2014 at 9:58am |
what a lot of people's fix is to knock the ball out of the return, and it will keep running. The problem is the flex ring is a cushion between two metal components. Now the cushion is gone, and then the rivets saw themselves into the end of the slot, putting metal filings in the pump, and eventually sawing the rivets completely off, resulting in potential runaway condition. Plus, knocking the ball out of the top fitting will allow all the particles to go right to the tank haunting you with supply issues later down the road.
m16ty
Posted: 29 Apr 2014 at 11:06pm |
When I'm into one I always install the updated, enclosed weight retainer to help eliminate the flex ring problem. Only down side is you have to re-time the IP because you loose your timing mark when you replace the weight retainer.
Another reason is I have a hard time installing a new flex ring over the rivets on the old retainer. They probably have a tool for it that I don't have.
injpumpEd
Posted: 30 Apr 2014 at 8:11am |
there is a tool to put the timing mark on the retainer. And the tool for installing the flex ring is a small snap ring pliers.
m16ty
Posted: 30 Apr 2014 at 9:56pm |
I just use one of those cheap metal engravers to put the timing mark on. I've tried the snap ring pliers for the flex ring but it's still a pain.
Andy190xt
Joined: 13 Oct 2017 Location: North Olmsted Points: 14 |
Posted: 13 Oct 2017 at 6:10am |
Hello, I am new to this forum. I can see this post was from a few years ago but I thought I'd ask anyway. I just bought a 190xt and I'm having this surging problem. The injector pump is said to have just been rebuilt. I was wondering how likely is a runaway? And what to do if it occurs? The air supply would be hard to cap off in a hurry.
Posted: 13 Oct 2017 at 6:34am |
If the pump has recently been gone thru, I'd be more concerned about dying in a car crash than the engine running away. If for some strange reason it does, you shift it into 8th gear and hold the brakes really tight and kill the engine. So, just to be prepared, make sure your brakes work well.
Andy190xt
Posted: 13 Oct 2017 at 7:26am |
Okay that makes me feel a bit better about that.
I've blown out the fuel lines, flushed the tank, cleaned the sediment bowl, and replaced the filter. What would you suggest I do now to track down this surging problem?
Posted: 13 Oct 2017 at 8:01am |
First thing would be set the low idle at 700 to 750 RPM. Slower than that can cause rough running in some cases. With the sediment bowls (there are 2) removed and fuel valve turned on, there should be TWO STREAMS of fuel flowing out. If not, there is a blockage in the inlet of the sediment bowl assembly.
Andy190xt
Posted: 13 Oct 2017 at 1:40pm |
Okay. I'll give that a try. The one sediment bowl is on the driver side so to speak under the tank. And ware is the second one? Right behind the injector pump? Does it have a little wire clip holding the top on? Also have you ever tried any of the injector cleaners that you buy at the auto parts store and dump in with your fuel? How do they work?
ksbowman
Joined: 19 Mar 2013 Location: Paola, Ks Points: 228 |
Posted: 13 Oct 2017 at 6:17pm |
I you are looking at the fuel tank one is on the far left side and one on the far right right behind the 3 point arms. The spring clip and plunger you are referring to ahead of the injector pump is the fuel primer to prime the pump and injectors if you run out of fuel
ksbowman
Posted: 13 Oct 2017 at 6:19pm |
I've tried the injector cleaners but, can't say they helped or not
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5083 |
Posted: 13 Oct 2017 at 7:18pm |
What injpumpEd hasn't said in this thread, is that he has an excellent reputation in his diesel repair service. He rebuilds pumps, injectors, and I'm sure a lot more, that he can tell you about.Knock on wood, I've had no diesel (pump or injector) issues for a while, but when I do, Ed is the guy I intend to call.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5317 |
Posted: 13 Oct 2017 at 8:36pm |
I will second that,Ed is the man. I bought a 190xt last year. Ed did mine about a year ago and what a huge difference. I recently had a similar situation with a slight surge bailing hay. Then, she failed to start the next day. Installed a new fuel filter the next day, bled the filter and my issue went away. Fuel bowls were clean but apparently there is dirt in the fuel tank. So glad the filter did its job, only 50 hours on it. I couldn’t be happier with his work. Turn around time was excellent.
