190 XT oil cooler |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7579 |
Topic: 190 XT oil coolerPosted: 23 Nov 2015 at 10:23pm |
screwloose
Posted: 24 Nov 2015 at 4:13am |
Oil cooler has tubes that run from end to end that the coolant runs through, engine oil runs through the outside of those tubes hence the coolant cools the oil. Oil drains back into the oil pan, coolant keeps circulating through engine anf radiator.
screwloose
Posted: 24 Nov 2015 at 4:14am |
Oil drains back to the oil pan or oil gallery
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 24 Nov 2015 at 5:27am |
Looks like you may just need to tighten your clamps. Worst case you may want to rebuild the hoses. Not a hard job, and Agco still has all the parts, new hoses, and new heat shields, clean the hose flanges up on a wire wheel and you should be golden.
Still in use:
Posted: 24 Nov 2015 at 5:40am |
When replacing the hose, use two new clamps to squeeze the hose ends and then wrap the heat shield around them and use a third clamp in the middle to hold the heat shield. This provides better clamping of the hose.
MACK
Posted: 24 Nov 2015 at 8:08am |
Oil comes from pump through cooler, then into oil gallery to lube mains, rods,turbo, and valve train. MACK
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8762 |
Posted: 24 Nov 2015 at 8:02pm |
Hey Fred! If it only held oil....what is cooling it?
slip knot
Posted: 24 Nov 2015 at 9:12pm |
That's an odd sized hose. 2 1/8 IIRC or 54mm. I had to buy a 3 ft piece when I replaced mine. I bought the HD 4ply hose and it was a real bear to get on. Way tight against the block at the waterpump area.
