190 xt gas? |
dr p
Joined: 24 Feb 2019 Location: new york Points: 1543 |
Topic: 190 xt gas?Posted: 05 Apr 2026 at 7:31am |
Old friend from the dirty jersey called me yesterday. An estate near him is cleaning up and has a 190xt gas they want gone. ( too newfangled for me) did they make a lot of them with a gas engine? Got to be the most powerful tractor i have ever heard that is gas?
Posted: 05 Apr 2026 at 7:50am |
190XT gas was 89 PTO HP. Deere 4020 and IH 806 gassers were in the 93 to 95 HP range.
Edited by DrAllis - 05 Apr 2026 at 10:46am |
DougG
Posted: 05 Apr 2026 at 8:24am |
There ok- gotta get used to the combine governor on them
dr p
Posted: Yesterday at 5:16am |
So lets say something for reasons that don't make any sense wanted to try and start this tractor. It is under cover but hasn't run for years. What would you do? I am thinking 1. Change the oil 2. Drain the gas 3. Rebuild the carburetor 4. Change the plugs. Anything else?
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4284 |
Posted: Yesterday at 5:24am |
Points will need filing.
Posted: Yesterday at 5:55am |
If it was me, I'm cheap. I don't know anything about the tractor. Loosen the oil drain plug to the last thread and let out a couple of ounces, looking for antifreeze. If none...screw the plug back in, the oil is OK to start it. If antifreeze is there keep draining until you get nothing but oil and then tighten the plug. Hang a gas jug with a rubber hose up high and connect to the carburetor inlet to gravity feed it, bypassing the fuel pump. Crank the engine while someone holds the coil wire close to the cylinder head and see if there is good spark or not. Got spark?? try and start the engine.No spark?? new points or whatever it takes to get spark. You'll need a good battery I'm sure.
DanielW
Posted: Yesterday at 7:06am |
I love my 180 gasser, which had the same engine as the 190 gasser (non XT), and a very similar engine to that in the XT. A farmer near our Northern farm has a 190 gasser (non XT) and it's sure a sweet-running unit. With the price of diesel being so much higher than gas these days, I'd be happy to find another 180/190 gasser. If you're using one on a really heavy load like primary tillage, it certainly sucks back the fuel and is still perhaps a little more costly to run than a diesel. But if you're using one for lighter work (mowing, baling, etc.), I find the fuel use doesn't vary too much from a similar-sized diesel. Couple that with how simple and smooth those engines run, and they make for superb tractors.
Posted: Yesterday at 7:32am |
8.0 GPH for the XT gas @ 89 HP. 5.7 GPH for the XT diesel A 93 HP. Probably not much savings on the diesel at todays prices.
MadCow
Joined: 27 Aug 2023 Location: South Dakota Points: 204 |
Posted: Yesterday at 9:14am |
From the very little I've run the diesel next to the gas. The diesel is much louder and diesel sounding. Running it all day would drive me nuts. Gas is a bit quieter and not so rumbly smoother, I have run it for at least half a day and haven't gone crazy.
Les Kerf
Yup. I use a portable outboard motor gas tank with the little rubber squeeze priming bulb for starting anything old that has a questionable fuel system. I do use 2-stroke chainsaw mix as I believe it may help with initial lubrication of the top end, and I am confident that it does no harm.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8406 |
Posted: Yesterday at 1:24pm |
If I’m not mistaken, IH did have an 856 gasoline.
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11871 |
Posted: Yesterday at 1:47pm |
Oliver 1850 and 1855 gas were 92 HP. Both 310 cubic inch engines. Almost 8 GPH at full load.
Edited by TramwayGuy - Yesterday at 1:49pm |
dr p
Posted: Yesterday at 6:47pm |
Going to go down next week and give it a try. Also found this cool antique wooden allis thing a mo bod. Will try and get a ten year old to teach me how to post pictures
IBWD MIke
Posted: 11 hours 56 minutes ago at 6:44am |
Yes they did. MM had the G-950 gas with 426 CI and propane models with a 504. Moline Dan on YouTube has a G950 gas with .030 (I think) over jugs from a 504. That's about 525 CI of gas loving engine! Glad I'm not buying the fuel for that!
Les Kerf
Posted: 8 hours 1 minutes ago at 10:39am |
According to my Nebraska Tractor Tests book the M-M G-1000 on propane at full boogy would burn nearly 10.5 gallons of LPG per hour!
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8780 |
Posted: 6 hours 34 minutes ago at 12:06pm |
My wife has acquired a Minneapolis Moline G 1000 Wheatland LP. Sounds like it's a good thing it's not going to be the main workhorse on the place Darrel |
Les Kerf
Posted: 5 hours 41 minutes ago at 12:59pm |
Reckon it all depends upon the price and availability of LPG vs Gasoline vs Diesel. It is nice to have options.
powertech84
Joined: 17 Oct 2009 Location: Wisconsin Points: 488 |
Posted: 2 hours 41 minutes ago at 3:59pm |
Oliver/Minneapolis Moline also made a 4wd tractor with an 8.3L LP engine. 169 HP.
Low production. Territorial Trading on Youtube has one that he's made a couple videos on.
Joe Goodwill
Bronze Level Access
Joined: 12 Sep 2009 Location: Souris Manitoba Points: 95 |
Posted: 19 minutes ago at 6:21pm |
Versatile model 125 used a 390 ford V8
