190 XT 3 STAGE PUMP
dog catcher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dog catcher Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT 3 STAGE PUMP
    Posted: 24 Mar 2021 at 6:51pm
3 PT AND REMOTES ARE WEAK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2021 at 7:30pm
First check oil level and make sure good , has the system oil and filter been changed ? Theres a screen on the sump that catches stuff too , may need to clean that -  then check pressures , also use good quality of oil , not 20 dollar for 5 gallon oil
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2021 at 9:04pm
there are two relief valves on valve stack, switch places with them. If that fixes the problem, you are good to go. If not, disassemble pump and check for blown seals or worn gears and housings .        MACK
This page was generated in 0.130 seconds.
