190 Loader Plumbing Confirmation |
MadCow
Joined: 27 Aug 2023 Location: South Dakota Points: 171 |
Topic: 190 Loader Plumbing ConfirmationPosted: 07 Jan 2026 at 7:32pm |
Finally have a joystick and everything mounted, looking to plumb. I read through this:
https://www.allischalmers.com/forum/joystick-install-with-pictures_topic138644.html?KW%20 And think I understand open center and the concept correctly. If I replace the union part "2" with 2 90s, then fluid would flow from pump through line "3", through elbow to loader valve in the red line. Then out of the yellow going to an elbow and line "7" . I have the power beyond plug, and this green line going back to tank. For rebustness sake is like the return to go through the filter, can I just do a T at part "15"? Or would it be better to just Tee off the drain plug? |
tbird
Posted: 07 Jan 2026 at 7:59pm |
have a c motor smokes just want to get rid of it 150.00 in eastern iowa
MadCow
Posted: 07 Jan 2026 at 8:04pm |
![]() Here's the sketch I made and forgot to post above. |
calico190xt68
Joined: 12 Jan 2017 Location: Frankton, IN Points: 874 |
Posted: 21 hours 8 minutes ago at 8:49pm |
Don't know if you saw my post on adding a joystick and loader to my 190XT, but here it is in case it helps. There are lots of pictures. It works good. |
MadCow
Posted: 9 hours 31 minutes ago at 8:26am |
Can't believe I missed that post!
Ended being almost exactly what I'm doing. But I decided to tap into the drain plug for return instead of at the filter. It's not as pretty, but I think it'll be simpler than dealing with the hard lines at the filter. |
