190 loader mounts. ?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Topic: 190 loader mounts. ?
    Posted: 25 May 2017 at 5:58pm
any one have a Du All 300  loader on a 190 ?
Id like to see pictures if you do.
Thanks Dave
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 9:18pm
I currently have my loader off my 190. What can I help you with?
WD,D15,190XT,7000,8010x2,7060,8070
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 9:35pm
If you truly have a 300 loader I don't think it will fit a 190 without a few modifications.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 9:52pm
Not sure if mine is a 300 but the tubes going to the rear axle were modified when I bought it. They were either lengthened or shortened and that appears to be the only modification to the loader. I will check the model number tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 6:20am
I don't have the tubes going to the rear axle. It's suppose to fit 50 to 100 hp tractors. I assume I'll need to make my own tube but I don't know exactly what they should look like. From what I see it mount with tubes going to the rear axle and has angle braces going foward to the engine area. I stopped this morning and looked at a local IH 866 with what I thought was a 300 on it the tubes going back to the axle and the cross support are one piece on it.  so I stopped at the JD dealer and an older JD has a 340 loader and the rear support tubes are seperate pieces with braces welded up to the engine belhousing bolts. I didnt pay much attentuion when I wqas at the farm this week there are two IH 986's with 325 loaders on them an I think the rear support and cross support were on piece also.
Edited by Dakota Dave - 26 May 2017 at 7:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 8:09pm
Hey Dave- I found the model number on my loader. It is a 3000 and its for sale. If pictures will help let me know. It may be similar to a 300, I am not familiar with that loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 11:04pm
Thanks a 300 is the generation before the 3000. It's a universial pin on loader that fits 50 to 100 hp tractors. I looked at several tractors locally and will fab a mount. There are almost no AC tractors here. Case IH and John Deere. Your 3000 should be a quick mount. I'd like to see a picture of the tractor side mounts if you've got one. Even if the mount isn't on a tractor.
Edited by Dakota Dave - 29 May 2017 at 7:42am
gerkendave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gerkendave Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 6:33am
I have a 325 that I have done extensive modifications to to make it fit my XT like I wanted. I have a full set of custom mounts that consist of four separate pieces plus the angle braces from factory. I also have shortened the loader arms to locate the loader as close to the tractor as possible. If you would like some pictures I can email or text them to you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 7:43am
I would love some pictures email to sodermand@polarcomm.com.
Thanks
This page was generated in 0.060 seconds.
