190 help
AllisandGleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Topic: 190 help
    Posted: 28 Aug 2016 at 8:24am
Is there a way to change a standard 1000 rpm shaft in on to just a 540?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2016 at 9:06am
Are you positive it doesn't have the swap around 540/1000pto setup ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2016 at 9:07am
If you have a single speed 1000 RPM PTO shaft on a One-Ninety, yes it can be retrofitted down to a single speed 540 PTO shaft. There wasn't too many made like that, and there are plenty of 540 RPM PTO parts in salvage yards. Now, which type do you have?? The manual shifted type requiring the foot clutch to engage it, or the optional hydraulic clutch type ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2016 at 10:02am
Has the little lever on the console
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2016 at 10:08am
Then, you'd need to buy a complete hydraulic PTO clutch box AND the driving gear up inside the torque housing. Also, the 540 shaft sticking out the rear of the tractor. You'll need a serious slide hammer puller with a 1/4" NC bolt to pull the two alignment dowels from the PTO box.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2016 at 10:32am
Does the tractor have a 2spd pto?
  Do you have a flange with three bolts around the pto shaft? thats single spd.
 If you have a flange and 4 bolts then it's the 2 spd.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2016 at 2:25pm
No I wish it did
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2016 at 4:14pm
Well, if your current situation is truly a single speed 1,000 RPM PTO shaft, you could remove the lift arm housing complete and swap it with the newer dual-speed 540/1000 RPM style housing and you're in business. The dual-speed housing was used on many late model 185 and 200 tractors and will bolt right on a One-Ninety.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2016 at 7:31pm
Would you have to change the gear in the front then
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2016 at 8:02pm
Nope. All you'd need is the complete rear(dual-speed) lift arm housing and it's inside drive shaft. The dual speed PTO system is 1000 RPM from the front and then reduces down to 540 RPM in the lift arm housing.
This page was generated in 0.301 seconds.
