190 gas snap coupler |
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4574 |
Topic: 190 gas snap couplerPosted: 27 Nov 2016 at 8:31pm |
I have a OneNiney gas 3 pt and have $1500 before I installed a Narrow Front. Just a toy that I pulled a few empty gravity bins to the field with. 185 diesel would be a better working tractor.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7574 |
Posted: 27 Nov 2016 at 5:53pm |
Depends what you are doing with it. If you plan to use it a lot, I would not bother with a thirsty gas. It is a bit of an oddball, but don't buy it thinking it will appreciate in value because it probably won't. |
kev/ont
Joined: 12 Sep 2009 Location: Castleton Ont Points: 282 |
Posted: 27 Nov 2016 at 5:08pm |
Myself i'd rather have a 185 than a gas 190 with snap coupler any day of the week. Diesel engine and 3 point are just two reasons. In our area, the price of admission wouldn't be a whole lot different either.
Other than camparible horsepower the two tractors don't really have a whole lot in common though. |
mruhlig77
Joined: 19 Aug 2014 Location: central Indiana Points: 595 |
Posted: 27 Nov 2016 at 4:52pm |
Thanks for imputs....do collectors consider this a good tractor...or an oddball...would a 180-185 be better or just as good...Mark
Hoss
Posted: 15 Nov 2016 at 7:29pm |
I've got a 190xt gas snap coupler. Got $2100 in it.
I got both ends meetin in the middle but I can't seem to get em tied.
Dakota Dave
Posted: 15 Nov 2016 at 6:32pm |
I have a gas snap coupler 190. I have $2000 into it. I paid $1000 drove it home and put some very used tires on it. Fixed the lights and ammeter. I've seen several on Craig's list between $3500 and $6000. 34" tires are imposable to find used in good condition and the tractors not worth the cost of new ones. If Ihad a use for it it would be worth more but it's a lot of over kill for the 6' mower and towing an empty hay rack around the yard. There mot very fast top speed is about the same as my WD 45.
nevans
Joined: 06 Dec 2011 Location: Red Bud. IL Points: 837 |
Posted: 15 Nov 2016 at 4:50pm |
we have a lp gas snap coupler 190 with a factory cab its a lot of fun to drive and doesn't use much lp on the grain augers and pulls a 6 ton spreader no problem Niel
Posted: 15 Nov 2016 at 2:35pm |
If you were moving up from a D-17, you might think gas engine and snap-coupler on a 75 HP One-Ninety. If you were thinking more acres, you'd buy a One-Ninety XT diesel with a 3-point hitch.
mruhlig77
Posted: 15 Nov 2016 at 11:12am |
Would this setup be a collector's item.?..if I found one...what should I pay....kinda looking for one with low hours...Mark'
