190 gas engine
Message Reverse Sort Order
allis3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis3 Quote  Post ReplyReply Direct Link To This Post Topic: 190 gas engine
    Posted: 30 Mar 2021 at 8:04pm
Thanks , I’ve located a tractor governor close to me , so I’ll pick it up this weekend, and try to get this thing fired up
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 8:01pm
Yes, on that engine. If you drill a new hole in the governor arm as high as possible for the spring to hook into, you should get close to 3,000 RPM I would guess. You'll have to modify the throttle cable anchor to aim the spring towards the new higher hole. If you need more RPM than what that gets you, connect a second spring in the old spring hole and anchor it somehow to keep constant tension pulling on the governor arm, so when you move the throttle lever you'll have two springs pulling. Governor action won't be great at part throttle settings, but will be gooood at full throttle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis3 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 7:52pm
Thanks for the info , so the tractor governor has lighter weights than the combine
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 1:36pm
I'd use a tractor governor and more spring pressure. The combine governor might explode at that RPM with the heavy weights flying around. Drill a new hole for the governor spring to hook into up as high as possible on the governor arm.
Edited by DrAllis - 29 Mar 2021 at 3:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis3 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 12:13pm
3000rpm limit
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 10:25am
All depends on what kind of rules you have to pull under.  Stock RPM's ??     Open RPM's ??   3,000 max RPM's ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis3 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 9:39am
I put it in a 17 frame for pulling was just wondering if I needed to change it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 6:27am
Governor weights are different/heavier on the combine engine if I remember correctly. This requires more spring pressure to get the same high idle speeds, but makes the governor much quicker responding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 9:38pm
yes ,but was wondering what parts were different , what I need to purchase
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 9:14pm
Governor on the combine is set to run at low idle and wide open with nothing in between.  Tractor governor gives you speeds between low idle and wide open.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis3 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 9:06pm
What’s the difference in governors between the G2800 engine in the tractor and the combine.
