185 Running Rough |
Slim
Topic: 185 Running RoughPosted: 22 Dec 2015 at 11:41am |
I bled the injectors and all but the one on #2 cylinder bled. I'm not getting any fuel out of that line. What can be the issue?
-Slim |
AC 1971 170 WF Gas, AC 185 Diesel WF, AC WD NF, AC '54 WD45 NF, AC 7080, AC 7030, Wheel Horse D-180 Automatic
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5148 |
Posted: 22 Dec 2015 at 11:54am |
yes, if no fuel is going to the injector, it won't fire that cylinder, thus rough running. Now, being a Roosa pump, it's uncommon for them to lose one cylinder. Check the line carefully, and make sure it came loose from the injector when you loosened the nut. Sometimes those stay sealed in the injector and have to wiggle the line to pop it loose.
MACK
Posted: 22 Dec 2015 at 9:37pm |
I saw one once when the opposing cylinder had the tip split. Why, don't know, maybe Ed can tell us. MACK
Thanks(1)
Posted: 23 Dec 2015 at 5:52am |
If the problem is truly as described, I'd guess the #6 injector tip may be stuck open or split.
Slim
Posted: 24 Dec 2015 at 11:17am |
So I was able to get the #2 injector to bleed. Still running rough though. What kind of wrench do I need to get the injectors out? They have like a zillion points.
-Slim |
injpumpEd
Posted: 24 Dec 2015 at 11:46am |
sounds like a 12 point socket is what you'll need, just regular tools. Either 5/16 or 3/8. The bolts are 5/16.
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 25 Dec 2015 at 6:44pm |
Pull all 6 send them to injpumped when the come back you will be another satisfyed cust
Edited by bradley6874 - 25 Dec 2015 at 6:45pm |
