185 questions
Wdtractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Topic: 185 questions
    Posted: 01 Sep 2014 at 7:58pm
I doing some custom track hoe work for a guy who has a 185 in a shed doesn't look like it been used in a while. It is a diesel I saw that but haven't look any closer sheet metal look far don't remember the tires. But I ask him how he liked it and he made it plane he didn't like it at all his list of things wrong was the pto was twisted off agen and a welded place in side of block but did say it had a good engine other than that it seams like he said something about the clutch but I don't really remember. Any way I have the feeling it could be bought cheep. Iv never been around 185 much so I was wonder if the pto was something that happens offended and what would be a good price on it if he does want to sell. Thanks in advance. Tomarrow I will try to look it over better and get some pictures
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2014 at 5:03am
I have never heard of any pto's "twisting off". Check to see if the 185 has a bolt on 540/1000 shaft (mine has that) or a straight 540 shaft. If it's the bolt on shaft, they are readily available for under $150.
It's hard to say what it's worth, but it sounds like it has had a rough life. I, personally, would rather look for one with less problems, even if I had to pay a little more for it. If you do pursue it, make sure the transmission is ok and it stays in all gears. The cost of a transmission repair can come close to the value of a 185.
