185 Fuel primer pump
TimZ(TX) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Topic: 185 Fuel primer pump
    Posted: 27 Jan 2015 at 7:51am
I went to fire up the 185 and it wouldn't start. Tried a little ether and fired for a second. New injector pump 2 years ago. Tried to pump up the manual primer and it was leaking real bad. Is there a seal or gasket in there or do you have to replace the whole unit. I think maybe it losing prime from this point.
Tim
2-B's,CA,D15,D17,160,2-185's 8010
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2015 at 8:02am
There are various parts in the plunger one way valves and o rings . You can take the wire bail off the end and pull the plunger out and inspect it more than likely just need the plunger.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2015 at 10:32am
I keep the plunger, and check valves and orings for those primers. The plunger is pricey though. It looks like they might be discontinuing it, it's not in the price book anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2015 at 11:17am
How could they discontinue a part like that Ed, It has to be a big seller.
