185 brake job cost? |
Butch(OH)
Topic: 185 brake job cost?Posted: 30 Nov 2015 at 6:11am |
My 185 has a little bit of brake on one side and zero on the other side. I know it depends on what is worn out or broken but looking for some kind of idea what I am getting into cost wise.
Thanks in advance! |
Rick
Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3695 |
Posted: 30 Nov 2015 at 6:25am |
Butch...Sent you a PM. Rick
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Posted: 30 Nov 2015 at 7:06am |
Educational opportunity, can someone explain the 185 brakes?
I looked at AGCO online parts book, saw a band and a clutch like friction disk? How dat work? |
MACK
Posted: 30 Nov 2015 at 8:03am |
The band tries to stop band. At that time it causes the drum to expand which applies pressure to the discs. MACK
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3664 |
Posted: 30 Nov 2015 at 9:09am |
on the AC D series, 100 and two hundred series, the LH brake 99% of the time goes out first. The fact that the LH brake always locks for parking ,,,, think it might have something to do with it?
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10937 |
Posted: 30 Nov 2015 at 9:29am |
Butch, catch Eldon on the next trip and have him do it. He has done quite a few lately. LOL Tracy
Butch(OH)
Posted: 30 Nov 2015 at 10:08am |
Yup, no brake at all on left side. |
Rick
Posted: 30 Nov 2015 at 10:17am |
I was thinking that by using the left brake when parking wasn't the problem, but maybe forgetting about it being set and taking off without releasing it might be! LOL! Rick
Rick
Posted: 30 Nov 2015 at 10:24am |
Seriously, I think that people probably go around the fields while brush hogging or plowing, etc., making more left turns than right turns could be some of the reason the left brake wears out first. I know when I was logging all the time, it seemed that I used the left brake most of the time, whether making a lot of left turns or trying to keep the front end uphill when skidding the logs. Rick
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 30 Nov 2015 at 11:07am |
If you are lucky you can get by with just replacing the pads and bands for under $100 a side. Last one I did didn't cost me a dime since I had some good bands laying around, a spare drum and some new facings for it just laying here. Worst case with shaft seals, springs, balls, linings, rivet tool, new drum and matching plate, new bands, new rods for bands, shims and new tranny fluid....you are looking at close to a grand. I just talked to a guy who had a shop do his 185 and he said it cost close to $1200.
ALLIS EXPRESS!
This year: |
Steve Zidlicky
Joined: 15 Sep 2009 Location: Bolivar, MO Points: 325 |
Posted: 30 Nov 2015 at 11:10am |
Rick, I have another twist-the right one should be the one used mostly during field work due to the fact that most work is done in a clockwise pattern unless you are backwards about doing things. the natural way to turn with pto operated modern equipment is to the right for less strain on the u-joints. the only exception is using the orange combines and roto balers which for some unknown reason to me the ac engineers thought they needed to build them to cut from the other side. of course that is what the engineers get paid for to make life harder for the operators of the equipment at times. with that being said, I also presume that most people use the left brake only for stopping because the left peddle is closer to the operator. the earlier D series tractors locked both brakes when the brake lock was used but when they went to the lock assy with the teeth in later series 15's and 17's and 100 series, it only locked the left side unless you flipped the latch on the peddles as you already know. just something to ponder on. Steve
Eldon (WA)
Posted: 30 Nov 2015 at 11:14am |
I'm not sure what the previous owner used my 175D with 1400 hours for, but the rh drum was 1/4" smaller in diameter than spec, bands were ground down to nothing, and the rh side sway block was worn so thin it bent and had been welded up at least once to add material to it. Plowing maybe??? Of course that is the hardest side to change.... ![]() ![]() Had to torch out the top pin.
ALLIS EXPRESS!
This year: |
Eldon (WA)
Posted: 30 Nov 2015 at 11:18am |
Steve if you have ever used a rotobaler or chopper with a WD or WD45 you can see how the normal seating position and use of the hand clutch would have been extremely awkward if you had to look to the right. |
ALLIS EXPRESS!
This year: |
Rick
Posted: 30 Nov 2015 at 11:19am |
Well, Stevo...maybe you're the one doing things bass ackwards? LOL! I've seen many folk that did field work the way I mentioned, but who knows. I've never heard of the u-joint thingy either, but then I haven't heard of a lot of things, I guess! LMAO! Since I haven't broken anything from doing it the way I have been, there's no use to change it now, right?
Rick
DanD
Posted: 30 Nov 2015 at 12:22pm |
On my father's 185, the left one wore out from plowing. When traction was poor such as on a field that had had manure spread on it over winter and was greening up with slippery clover you hit the left brake to get through those spots. Would have loved a differential lock. If it was really bad we put a tire chain on the left occasionally. Even then it took 30 years to wear it out. We put the kevlar discs on from AGCO and new bands. Didnt need anything else at the time. Still works great. Right side is still original.
Steve Zidlicky
Posted: 30 Nov 2015 at 3:14pm |
Eldon and Rick: not trying to start another p-ing match. I guess I am like some others that come hell or high water, if I think I am right and you cannot prove me wrong then I have a hard time giving up although it would probably be in my best interest to just shut up!! I have used ac tractors more than all of my adult life and that is a looong time in dog years, but was always fortunate to not have to endure the comfort of a nothing older than a d series in the Allis Chalmers line, so I did not even include a wd or 45 in my thoughts about twisting around on one of those models. Eldon, you are correct with your point. as far as the strain on the pto driveline, if you pull a non-3 point piece of equipment with any make or model of tractor and turn short to the left it will chatter causing more strain and wear on the driveline. The only exception to that is the newer double u-joint drive lines and they were designed to reduce the strain even on right turns due to the even higher horse power being applied by tractors now. Even those shafts need to be used with some amount of care or else you will be spending $1,000 plus for a new shaft and they do sell new ones. I do not pretend to know it all but have been farming full time since 1969 so if you have seen a lot of people turning to the left using modern pto equipped machines that are of pull type using a drawbar such as a haybine,square hay baler, pull type brush hog (not 3 point) either they do not hear well,haven't read the operators manual, or just plain ole don't care how to take care of their equipment. If using a 3 point implement, you could spin in circles to the left all day long and would have no effect on the drive line because it does not bend while you turn. Rick, just to be clear, I am talking about using PULL TYPE PTO EQUIPMENT ONLY, so cool your jets and rethink before deciding I am the one going bass ackwards. Maybe I was not as clear as I should have been so my brain or what is left of it would match my typing with my thoughts. I was raised on farm income only and went through some lean years and we had to do it right to keep repair costs down. Still your friend, Steve
Rick
Posted: 30 Nov 2015 at 3:32pm |
Steve, ol' buddy...I don't think I was saying anything at all where I need to cool my jets. Yes, I have seen many people turn to the left while using pull type equipment. If they broke something, then it was their own fault. Me...I'm smiling, because I WAS talking about three point equipment! LMAO! So see...there's really nothing for me to rethink!
Your buddy, Rick P.S., You should have stated PTO PULL TYPE EQUIPMENT ONLY.
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 30 Nov 2015 at 3:40pm |
I have so !#!$#%!! much brush and trees on my field edges that I need to clean up, I usually start outside brush hogging or discing in a field based on which side the muffler is on to keep it as far from the branches as I can. On a D17 the muffler is on the left so that means counter-clockwise and my 180 gas it's on the right so I'd do it clock-wise. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
Rick
Posted: 30 Nov 2015 at 3:53pm |
Mike...LOL! That's funny, but true enough! Anyway, I wasn't trying to make anyone mad on here by any means. It seems that some have short fuses here lately and could be taking some things wrong and it's not even winter time yet! LOL! Rick
KY poorboy
Posted: 30 Nov 2015 at 4:16pm |
Each to his own I guess. When I am pulling a 32 foot disk or cultivator, forty or sixty foot planter, or anything with any size, I want my right side to the fencerow, so I can sit a little crooked in the seat and look over my right shoulder. That way, I can just look down and quickly grab the controls if needed. Soooooo, I normally work a field counter clockwise.
Now given a hay bine or square baler or such, it is a given which direction to operate, except for finishing a field. But I do have one question....you say any pull type pto equipment is to be pulled and turned clockwise in a field, such as baler, mower or pull type bush hog, what possible difference could it make what direction I turn with a pull type bush hog or hay roller and alike with a centered driveshaft, whether it be a CT joint or regular joint?? This I do not understand. Please explain. |
Steve Zidlicky
Posted: 30 Nov 2015 at 5:28pm |
when turning right you turn a different angle in relationship to the direction of the pto which is clockwise standing behind the tractor. when turning right the opposite angle is put on the shaft and the applied power is harder for the u-joint to be compatable with. as far as the driveline being straight behind the tractor, most of the second joints back are not exactly in line with the hitch pin so you still have the angle situation to consider even though it is a 3 joint drive shaft. if you understand fine. if you agree fine. if you disagree fine. either way, I am done.
bauerd44
Silver Level Access
Joined: 11 Sep 2009 Location: Wentzville, MO Points: 350 |
Posted: 30 Nov 2015 at 5:35pm |
I just spent $1500 for brakes on our 185 about a month ago. I got some other things done and paid more for that. Brakes are amazing now.
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis |
DougG
Posted: 30 Nov 2015 at 5:41pm |
Always figured about 400 per side, labor, parts and cussing
tbran
Posted: 30 Nov 2015 at 9:15pm |
we never price a "brake job" - we ask if you want it patched or fixed correctly . We have spent 2 hours just getting broken lug bolts out.
Sometimes the pins come out, sometimes not. Sometimes cleaning up oil leaks takes time. To do a job right, both inner and outer friction surfaces should be machined, them re shimmed to correct dimension. This takes time. A correctly done job - and the customers not driving with the parking brake on - will result in like new performance and long life. Brake jobs have run from $650 to $1650 on wipe out cases... |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5191 |
Posted: 30 Nov 2015 at 10:30pm |
When I was mowing chopping or baling hay or cutting corn, I mostly turned to the right. I sometimes turned to the left in the center of the field to lessen time travelling across the end.
Plowing and discing, I turned mostly left. Does that make me ambidextrous??? |
ILGLEANER
Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Posted: 30 Nov 2015 at 10:52pm |
Which way the pto is running or not , have nothing to do with the brakes. I don't care what side you start on, you are going back and forth. Left then right, left then right, left then right. So no matter what side of a field you start on, has nothing to do with what brake wears out quicker. You guys need something else to think about.
IG |
