185 alternator draining batteries
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: 185 alternator draining batteries
    Posted: Yesterday at 1:06pm
Why is the field terminal always HOT even when the wire is disconnected and ignition off killing the batteries over nite? 1100887 55A delco. Thanks Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 1:22pm
the HOT WIRE to the battery is probably always hot.... You might have a small leak internal that goes to ground... that could keep the F terminal warm..
Disconnect the battery cable terminal should work...
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 1:38pm
Sorry I worded that wrong ! The F terminal is causing a Draw. My bad, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:45pm
you have an external voltage regulator... are you thinking the contact INSIDE the voltage regulator is STUCK closed and causing a draw when you connect the Field wire ?
Maybe the REGULATOR and not the Alternator ?
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:32pm
Could be a shorted diode in the alternator or contact in regulator welded to hot post. or connectors put on wrong terminals...
  55 amp alternator means that tractor has a different alternator put on. Original was 32 amp alternator.
 Is that 1100887 alternator still the old Delcotron style? no regulator inside it...?
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 29 minutes ago at 7:10am
Steve & JC-WI, yes it is a older Delcotron alternator, draw is happening with regulator disconected, will pull & open Alt & test diodes n other stuff, Thanks Dave
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 4 minutes ago at 8:35am
I believe that the 10dn Delco alternator can be bumped up to a 55 Amp by just using the heavier windings. Seems like I put some 72 Amp windings in a 200 once for cab,AC, and planter blower fan load. I would suspect a bad diode is causing the field terminal condition. There's not much to those alternators, stator, windings, brush set, and two sets of diodes.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 49 minutes ago at 10:50am
Contacts are probably sticking on the voltage regulator
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 35 minutes ago at 4:04pm
Bad voltage regulator was what got me all excited yesterday, l didn't have new one but had a newer style alternator with the internal regulator on the shop shelf that I had rigged up as a spare for one of the 8010's if needed in a pinch, jumped the field wire to the ignition switch and all is good, tack don't work very good but I can live with that for a while. Thanks Dave
