185 alternator draining batteries |
automaticdave ![]() Silver Level ![]() ![]() Joined: 20 Jan 2011 Location: Granton, ON Points: 248 |
![]() ![]() ![]() ![]() ![]() Posted: 15 hours 49 minutes ago at 1:06pm |
Why is the field terminal always HOT even when the wire is disconnected and ignition off killing the batteries over nite? 1100887 55A delco. Thanks Dave
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 85499 |
the HOT WIRE to the battery is probably always hot.... You might have a small leak internal that goes to ground... that could keep the F terminal warm..
Disconnect the battery cable terminal should work...
Sorry I worded that wrong ! The F terminal is causing a Draw. My bad, Dave
you have an external voltage regulator... are you thinking the contact INSIDE the voltage regulator is STUCK closed and causing a draw when you connect the Field wire ?
Maybe the REGULATOR and not the Alternator ?
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34188 |
Could be a shorted diode in the alternator or contact in regulator welded to hot post. or connectors put on wrong terminals... 55 amp alternator means that tractor has a different alternator put on. Original was 32 amp alternator. Is that 1100887 alternator still the old Delcotron style? no regulator inside it...? |
