184 mower gearbox
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: 184 mower gearbox
    Posted: 20 Apr 2016 at 11:00am
i have all the parts rounded up, bearings, seals, shim gaskets but i can't get the front bearing pulled off of the input shaft. it is tight against the gear and i can't get a bearing separator behind it. i'm scared to press the shaft because i can't get it out of the gearbox housing. any suggestions would be greatly appreciated.
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 2:44pm
I'm assuming it's a tapered roller bearing?? If you have room, torch the roller cage off removing the rollers, then carefully torch the rest of the bearing off the shaft. If you don't want to use a torch, a die grinder works good also. Do the same except don't grind all the way through the bearing that is on the shaft. Grind through leaving just a little as to not go through and booger the shaft. Then take a chisel and put it in the groove you cut with the die grinder and give it a good whack. Bearing should split and release the tension and be able to be slid off shaft easily. Hope this all makes sense.
Just my 2 cents...
Good luck!
Ben
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 4:45pm
If you could get some sort of prying tool between it and the gear, you might take a torch to the inner race in a small area , heating it quick and prying at the same time. Once the heat gets to the shaft, it will catch up with the growth of the race real fast. One pry bar on each side and a 3rd hand to run the heat, would make it easier.
This page was generated in 0.652 seconds.
