180 pto problem
AndyinWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyinWI Quote  Post ReplyReply Direct Link To This Post Topic: 180 pto problem
    Posted: 26 May 2015 at 11:08pm
I just put a new clutch I my neighbors 180 allis and now the pto doesn't work. It was working before I split the tractor. All other Hyd functions work like they should. Any help is appreciated.
Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 7:05am
Well, we have a choice of TWO clutches......foot clutch......hand clutch. If you installed a new foot clutch, I see no connection between the repair and the PTO problem. Hand clutch ??? Yes, probably need to manually shift the short lever behind the battery box back into gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyinWI Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 8:31am
I replaced the foot clutch. It has the Hyd pto and I was figuring it has something to do with having the lines apart when I split it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2015 at 9:08am
I'd still check the PTO coupler shifter behind the battery box...rotate fully counter-clockwise to engage. Someone might have to turn the shaft at the rear of tractor while you shift the lever.
