180 power director valve |
shackratt
Joined: 06 Jan 2016 Location: Patriot Indiana Points: 70 |
Topic: 180 power director valvePosted: 08 Nov 2016 at 5:22pm |
I have a 180 power director valve that I cannot seem to get the spool to come out. It is stuck pretty good. Anyone have any ideas on how to get the inner spool out?
Thanks in advance Sam
AC 180, TO-20, Case 580B Case 450 dozer
MACK
Posted: 08 Nov 2016 at 10:07pm |
Do you mean the one the shifter is hooked to or the pressure regulator? MACK
shackratt
Posted: 09 Nov 2016 at 4:28am |
Mack, The valve that is connected to the handle to switch from High to Low. I have removed the valve and tried to remove the inner spool. The little plunger with the spring comes out but the upper most portion (cup) will not come out. I have tried soaking it for days. I was thinking of drilling a small hole inline with it and pushing it out that way then tapping and plugging the hole. The tractor stays in High even if you shift to low.
thanks for the reply sam
Posted: 09 Nov 2016 at 7:10am |
Just find yourself a used valve from a 180 or 185.
WD45Diesel57
Joined: 20 Jul 2010 Location: Varna, Ont. Can Points: 646 |
Posted: 09 Nov 2016 at 10:38am |
i have a good one here on a parts machine if needed, the lever clicks through smoothly but sharply
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
