180 getting water in the transmission
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 180 getting water in the transmission
    Posted: 22 Nov 2011 at 6:05pm
Working on a 180 AC , drained the transmission oil out and about 2 qt.s of water came out first ; is there a seal or o-ring on the shifter any where ? Everything else seems sealed good
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 7:13pm
          There is a rubber seal on the shift lever. I replaced the one on are 180 a long time ago and can't remember exactly how I did it. Someone will get you the directions for doing this.
                                                 John Carlson
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 7:43pm
I'm looking at the service manual now.  I don't see any o-rings; only a dust cover.  The 7000 shows a gasket under the transmission cover.  I don't see one for the 180.  Perhaps there is a gasket under the cover and the water leaked in between a loose bolt and the gasket.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 10:16pm
Does the tractor spend lots of time outside?  The only way water gets in there is from a gear shift boot that is torn/rotton.  Take the shift knob off and put a new boot on.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 10:21pm
My two 180's don't have a rubber boot on them,but what looks like a steel shaped umbrella over the shifter where it goes into the tranny. Sitting outside for long periods of time will do this. That rain water will get in anywhere,if left outside.  Rick
