180 brake replacment how bad
rudyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Topic: 180 brake replacment how bad
    Posted: 08 Nov 2016 at 6:09pm
How bad of a job is it to do the brakes on a 180
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 6:10pm
Left side easy Right side quite a bit harder
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 6:11pm
whats the best way to go about it, I am very inexperienced in this
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 6:33pm
It is best to have a good floor to work on and a cherry picker to remove the final drive. Remove the seat and fenders. Drain the transmission if you plan on replacing the shaft seal. Remove cylinder pins...this can be your first hurdle if they are rusted in. Jack up one side (do one side at a time). Remove cylinder bracket and remove final drive. Remove pins that hold brake bands in (hurdle #2). Take brake drum off shaft and put final drive back in tractor. Measure gap where brake drum was..I think it need to be 2.03 to 2.04" if my memory serves me right. If it doesn't fall in this range, you have to add shims to the final drive side. Remove and shim if necessary. If changing inner seal, remove housing and do that. Rivet new pads on brake drum, check springs and balls and re-install with final drive, careful not to damage the inner seal. Rivet new pads on bands and reinstall. Assemble the rest of the stuff and adjust brakes. Here is a pic of how I dealt with the hydraulics side. After you do 4 or more it gets easier LOL!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 6:47pm
Some more pics
Top hole is why the cylinder bracket has to come off...I used a half inch bolt and washers to make a puller to get this pin out...you may have a slide hammer to use.
You will need a good 12pt socket to get this bolt out that holds the cylinder bracket on.
Tie up the cylinder so you don't damage the hose.
You might have to use a hot wrench to remove some parts....fortunately I had spares.
I order a little rivet tool from these guys and did my own pad replacements.
ALLIS EXPRESS!
This year:
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 7:56pm
You can do it. Did our D17 IV and very similar to yours. Just need a chainfall and a rigging point in the barn or garage, another set of muscles to pull the final drives off. Used a chainfall to get them off. Took maybe 6 hours for each side. But we did one side, ran the tractor for a few weeks and then did the other side. So we had to take things off again, but what else am I gonna do with my time???
Hammer and flat punch for peening the rivets.
Edited by Stan R - 08 Nov 2016 at 7:58pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 8:58pm
Don't need to remove lower cylinder bracket. I never go to the trouble to try measuring between the two ware surfaces. Replace what is needed, slide final drive back on, tighten two bolts and with feeler gauge, check clearance between drum and one ware surface. If it is between .060 and .090, finish job. If not remove final drive and +or- shim according.   MACK
This page was generated in 0.168 seconds.
