180, 3 point lift creeps up? |
nsula_country ![]() Orange Level ![]() ![]() Joined: 10 Mar 2011 Location: NW Louisiana Points: 218 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Jun 2011 at 11:13pm |
I have noticed when mowing the 3 point lift creeps up. The cylinders leak a little out the vents when parked, but I have kits for them. If they were an issue they would creep down. Could it be my valve is not centering properly? Can the centering detent be adjusted. Is the valve worn? Thanks, CT |
Traction booster linkage needs adjusted or linkage at valve is sticking. MACK
All the linkages from the "torque" link where the base of the lift arms are to the traction control levers themselves are gone. those two short levers are decoration. I'd like to repair that some day. I'd like the draft control to work again.
The handle seems stiff in places like the detent or linkage is sticking. I'll check into that. I'm thinking valve. CT
