175 steering leak |
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Topic: 175 steering leakPosted: 16 Aug 2011 at 11:30pm |
My 175D started dripping oil from the top of the steering column (under the steering wheel). I assume a seal is bad somewhere, anyone else have this problem? If I have to remove the hydro motor to fix, I guess I might as well swap in the whole unit from the parts tractor....or is the seal up by the steering wheel?
ALLIS EXPRESS!
This year: |
bauerd44
Silver Level Access
Joined: 11 Sep 2009 Location: Wentzville, MO Points: 350 |
Posted: 17 Aug 2011 at 12:23am |
Eldon, I don't have a leak, but I looked at the AGCO parts book and it does not show a seal up high by the steering wheel. The seals are all in the power steering valve. Here is the link to the pages.
Hope this will help you. Dale
skipwelte
Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
Posted: 17 Aug 2011 at 11:17am |
Swap out the steering motor from the parts tractor, those can be more trouble than they are worth to try and fix a leak Eldon. |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 17 Aug 2011 at 9:44pm |
Who's to say the one in the parts tractor is any better?
BrianWI
Joined: 11 Sep 2009 Location: northeast wi Points: 27 |
Posted: 19 Aug 2011 at 12:58pm |
I had the same problem with my 175D. I removed the steering valve form the tractor
and replaced the o-rings and dust seal on the shaft end and the problem was solved.
My local Agco dealer had the seal kit in stock.
Eldon (WA)
Posted: 20 Aug 2011 at 12:05am |
Well it is the old procrastinating fix.....it isn't leaking now.
ALLIS EXPRESS!
This year: |
