175 pistons in d17 gas? |
vyvyjim ![]() Bronze Level ![]() ![]() Joined: 11 Sep 2010 Location: WAUKESHA, WI Points: 146 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Aug 2011 at 6:53am |
My series IV D17 needs an engine overhaul and I'd like to add horsepower. Could I just put in 175 pistions and get a 10 hp boost? Or is there more to it? What would be other reasonable ways to add horsepower in an overhaul?
Matt MN ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
the 175 pistons do have a higher compression ratio which will help, also the 175 had a different camshaft and governor weights and spring which made more horsepower.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22010 |
Higher compression, and a different camshaft AND a different larger carburator......governor control raises rpm rated to 1800 instead of 1650.
