175 hydraulics |
Kirkp ![]() Bronze Level ![]() ![]() Joined: 15 Mar 2022 Location: Ontario canada Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Mar 2022 at 10:11am |
Working on a 175 no hydraulics, dropped sump no oil yet dip stick to left of shifter says full
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21724 |
Well, if there's no oil in the hydraulic/torque tube sump, you'd expect the hydraulics not to work. Hard to believe the screw-in dipstick has any oil on both sides of it after being wiped clean and re-inserted for an oil level check. I think you need to drain the plug directly under the clutch pedal, carefully clean the screen above the sump and refill with 5 to 5 1/2 gallons of oil. Then, I know it's full. |
If you drained system for some reason and refilled, it takes a while for oil to get up to there. Unhook return line on left side to help vent system MACK
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3511 |
side or front pump?
