175 hydraulic parts
Mdguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mdguy Quote  Post ReplyReply Direct Link To This Post Topic: 175 hydraulic parts
    Posted: 29 Mar 2022 at 8:16pm
Does anyone have a source to get the connector hub(bolts to crankshaft pulley), shaft that runs from hub to pump and the 2-17 tooth sprockets that run the front mounted hydraulic pump on the 175 diesel. Sorry if the terminology isn’t correct.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 8:48pm
Alex at A & W tractor If he don't chime in PM me I will get you his number
Albert
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 8:57pm
Sure! Thanks Albert! We have all those front hyd pump drive parts in stock.
A&W Tractor 920-598-1287
www.awtractor.com
A&W TRACTOR 920-598-1287
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 8:57pm
There is a hub on ebay. I think the seller is on this forum. he also has the shaft.
Surpluscenter.com has chain couplings. Standard 40P couplings have 16 teeth sprockets.
The engine and pump end sprockets have different bores.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2022 at 9:07pm
I was too slow
