170 hydraulic pump leaks
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Topic: 170 hydraulic pump leaks
    Posted: 05 Nov 2021 at 8:34pm
I started the 170 gas black stripe today, and now have a leak at the outer cover area.  I don't see any damage to the pump, and it was fine when I last used it a couple weeks ago.  Looking at the parts book, it appears I need a 255947 seal kit.  Is Agco the only source for this kit, and is it sill available?  Anyone have any advice on fixing these pumps before I take it apart?  I've rebuilt gear pumps in the past, but not one like this, so I'm guessing it shouldn't be to hard to do, and to do it correctly, all 6 kits should be put in at the same time, correct?
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2021 at 8:51pm
one kit is for one section also need front seal.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2021 at 5:41am
Thanks, Albert, so is Agco the only source of parts for this pump?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2021 at 6:19am
Ebay have them.                            MACk
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2021 at 7:17pm
Thanks Mack, I'll check that out!
