170 gasser ? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10874 |
Topic: 170 gasser ?Posted: 15 hours 12 minutes ago at 9:17pm |
My 170 gas has puzzled me. Repaired replaced alternator. Repaired voltage regulator harness. Replaced voltage regulator. Worked great. No problems. A couple months later, will not click or try to turn engine over. Would not jump across post to energize solenoid. What could cause the drain on battery? Could new regulator be stuck and drain it? Thanks, Tracy
Joined: 11 Sep 2009 Location: illinois Points: 89291 |
Posted: 13 hours 41 minutes ago at 10:48pm |
your going to have to run a few tests.. Battery could be bad.. alternator could have internal short... voltage regulator could have contact STUCK and being grounded... and then any of the wires between them could have a problem...
I would start with a fully charged battery.. disconnect the + cable and let tractor set for a couple days.. reconnect and see if battery went dead on its own, or has full charge... Get a amp meter in the line and see what is being drawn out of battery when setting with the key off....... if battery is good, start looking at the alternator / regulator / or even the starter motor... Is any of them feel WARM to the touch ?
Tracy Martin TN
Posted: 12 hours 54 minutes ago at 11:35pm |
Steve, battery is almost new. Alternator checked good. I put a new regulator on it, but I wouldn't swear it is good. Ain't like the old Neihoffs . My meter was dead today, low battery. I will charge up the battery and test from there. Thanks, Tracy
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1188 |
Posted: 12 hours 15 minutes ago at 12:14am |
Pull one of the battery cables off in the dark and slightly touch it to the post you pulled. If there’s an any slight spark there’s a draw. You can tell by the size of spark how bad it’s drawing.
Newer vehicles have a draw all the time (that’s why they don’t sit as long with a charge). I don’t think alternators are supposed to have a draw… I will start pulling wires and check for spark until the spark goes away and chances are that circuit is possibly the problem. |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54727 |
Posted: 8 hours 3 minutes ago at 4:26am |
Never pull wires off of a running engine (alternator equipped). It's a good way to blow the diodes...
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3127 |
Posted: 4 hours 58 minutes ago at 7:31am |
I had about the same issue with my Oliver 1550 gas,regulator was the problem as they are pretty much junk these days.A 1 wire alternator from DB Electrical fixed the problem.
Posted: 4 hours 46 minutes ago at 7:43am |
There are "modern" regulators for those old Delcotron alternators, that don't have breaker points inside to stick and run the battery down. They look the same but are electronic on the inside. A nice upgrade and it still looks original. I'm pretty sure if the regulator points stick when shutting the engine OFF, if you notice (which none of us do), the ammeter will show a slight discharge, and not return to true zero.
55allis
Posted: 3 hours 17 minutes ago at 9:12am |
Only do that with the engine shut down. |
RedHeeler79
Joined: 09 Sep 2023 Location: NE Kansas Points: 212 |
Posted: 2 hours 58 minutes ago at 9:31am |
An easier method than looking for a spark when touching battery cable to post…. Disconnect the ground cable, and hook a test light between the ground cable end and the negative battery terminal (assuming negative ground). If there’s a draw, the test light will illuminate, and the brightness will give you an idea of how strong the draw is. You can leave it hooked up this way and disconnect components or pull fuses one at a time until the test light goes out. Easy way to find a draw without a multi-meter.
