170 gas tractor fuel line? |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10824 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Aug 2011 at 8:08pm |
Anybody got a late 170 with sediment bowl outside of side panels? I want to convert mine and need a pic of where the bracket for bowl goes. That bowl under the tank was real genius at work. Thanks Tracy Martin
Larry B ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: charter oak Ia Points: 386 |
mine screws into the carb.
Larry, mine has a bowl at the carb also. Manual shows a bracket, part # 0257497-8. Has a screw,self tapping 10 x 1/2.Mine has the bowl under tank, and it is just a problem with cutoff there. I wish I could see a pic of how they were from factory on late 170's. Thanks Tracy Martin
Any pics of a sediment bowl on late 170 would be appreciated. Thanks Tracy Martin
Edited by Tracy Martin TN - 23 Aug 2011 at 8:19am |
Slade (TN) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: TN Points: 676 |
They just knew you would be the proud owner of one at one point or another Tracy, no big deal man!!! lol
I just want to get rid of the leaking compression fittings and line. They will be flare fittings from here forward.I have a late model kit. Just can't figure how the sediment bowl and bracket goes. Thanks Tracy Martin
Pizzaguy ![]() Bronze Level ![]() Joined: 15 Sep 2009 Location: United States Points: 29 |
My 170 sediment bowl screws into the carb also. Cant post a picture because it is apart to install a carb kit. Anybody know where to get a new fuel shutoff to replace the leaky one under the tank?? I believe it is 1/8" NPT threads and it is a 90 degree elbow. Can't find one anywhere. |
1972 170 with Year-A-Round Cab
