170 Gas Baling
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Topic: 170 Gas Baling
    Posted: 31 May 2018 at 7:09am
Anyone pull a round baler with a gas 170? I have 2 Oliver 1550 tractors gas and diesel
I pull a NH 851 baler with OK and they are 53 PTO HP and I'm thinking about a gas 170
that's rated at 54 PTO HP but wondering if the gas 4 cylinder has the power to get the job done?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 7:19am
53 or 54 HP from a 4 cylinder should be the same as from a 6 cylinder.  Torque X RPM makes HP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 7:40am
Guess you're right but the reason I wanted someone to chime in that's run a 170 on a baler is I have a 4 cylinder International about the same HP and governor stays wide open once the baler starts to make a bale and its just too much for the IH to pull.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 9:51am
Well  Gary   being all your ground is on the  flat and level . LOL
Edited by Fred in Pa - 31 May 2018 at 9:51am
nonetheless ,still dead.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 10:41am
I have pulled an 851 with my 175D in the past and it is a load. Up hill with a full bale is all it wants. I don’t remember what the hp is on it. I think around 65. If you have a bigger horse I think you would be better off using it.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 10:47am
The torque curve is probably flatter on a diesel.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 11:01am
I would look towards a 180-185 with hydrulic engagement on the PTO-- since you have not bought anything yet. Just my thoughts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 11:50am
I have a 180 and a 185 but wanted to know if the 170 would be capable to use on the balers if needed.
