170 engine block stamps?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: 170 engine block stamps?
    Posted: 23 May 2016 at 11:42pm
What number would be stamped in a One Seventy gas block, and what in a 170 gas engine block? Did AC put a engine block in a 170 with fuel pump hole and delete plate?Did they stamp a 7,17, or 170 in them? Thanks Tracy
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 7:33am
17 then a z suffix. No fuel pump hole.   If there is a fuel pump hole with plate then engine is replacement..most likely from a Gleanet E....which may have the z suffix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 10:10am
...was there a time when a 226 replacement block was combine type to cover all bases? replacements have no markings unless installer added
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 10:33am
Lot of the 170 blocks had a yellow chalk written on dist. side under the paint, can't see it till the paint wears away...  170
