170 and wd value? |
dewn81
Joined: 30 May 2010 Location: East Central Mo Points: 65 |
Topic: 170 and wd value?Posted: 24 Apr 2017 at 6:30pm |
What would the value be of a 170 gas that is very rough but is complete and In need of a engine overhaul? Aslo what is value of a wd that is rough and complete but it doesn't run?
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7574 |
Posted: 24 Apr 2017 at 9:09pm |
Very little for both. They are both rough and not running/need rebuilding, your best bet would be to either part them out or send them to China. If they weren't rough, I would probably rebuild the engine. and go from there. No more than $1000 for the 170 and $250 for the WD.
DanWi
Posted: 24 Apr 2017 at 9:35pm |
Depends tires pretty good? or shot? Have to start looking at what the pieces are worth also depends if you do engine over hauls yourself or hire it all done.
corbinstein
Posted: 25 Apr 2017 at 6:33am |
'bout right on the WD.
Posted: 25 Apr 2017 at 7:25am |
And if the One-Seventy is a runner, take it down a steep hill in 3rd gear high side at full throttle and cut back fully on the throttle to see if it jumps out of 3rd gear. That long shift lever was a bad idea, as it allows more grinding of the gears by an abusive operator.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3127 |
You can fix a broken tractor and you're good to go,with a worn out one repairs never ends.
