160 Hydraulics
TimZ(TX) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Topic: 160 Hydraulics
    Posted: 25 Sep 2016 at 7:09pm
My 160 hydraulics quit working after a few minutes of running.   You can turn it off and start it up and they work.  Then it repeats.   I changed fluids.  I cleaned the elemts under the tank.  Can those be bad?
Thanks Tim
2-B's,CA,D15,D17,160,2-185's 8010
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 9:04am
Any ideas?
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 9:46am
Was it low on oil, it takes 29 quarts of oil (7 1/4gal). I would assume you put the correct amount back in at the oil change, and it still don't work right, so hmm. Usually they lose prime, so no pressure at start. But yours works, then stops.  What hydraulics are you using, just the 3pt? But if you are sending oil out to large cylinders, then maybe it is lack of oil.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 11:26am
Thanks Tim
Did you clean the other two screens? One is forward of the shifting lever by the remote levers, and the transmission/hyd screen just forward of the seat?  Dale
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 9:05pm
think the above pics are the key - are you running universal hyd fluid? Origionally they had a thicker oil - but actually run better on the thinner 821  we have actually punched small holes with an ice pick in the strainer to facilitate oil flow when cold-  the other issue- and hope it is not it, is if the gear is spinning on the pump shaft...
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 9:50am
I drained the oil and filled it up until the side plug flows. I used universal which is supposed to be close to 30wt. I cleaned the element in figure 19. By the way that replacement is almost $250 (ouch). I will clean the screen next.   It's both the 3 point and remote cylinder. The pump was replaced 2 years ago. I will also check to see if there might be a crack in a hose that would cause it to loose prime.
Thanks Tim
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 4:55pm
Well I found the problem. I took out the screen in the transmission out. It was so clogged it was disfigured.   I was going to take a picture of it , but I would be too embarrassed to show it. I missed that when I bought the tractor and changed all the filters. Hydraulics work great now. Thanks for the replies.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 6:47pm
Dale and Tbran nailed it, home run.
These tractors are at the age where dirt and corrosion are an issue.
For instance, my fuel bowl is getting a collection of rust now.
But the hydraulics suction strainer was clean on mine.
Tim, if you did take a picture, please post it, would like to see.
Edited by BrianC - 03 Oct 2016 at 6:49pm
This page was generated in 0.207 seconds.
